Bosch SHU43C02UC/17 Cleans like @*&%!!!
3 replies to this topic
#1 sirwired
sirwired
    Ikkō-ikki
  • Appliantologist
  • 30 posts
Posted 03 December 2010 - 10:08 AM
I, appliance-using-peasant, humbly beseech my appliantological masters for aid!
Our Bosch over-priced junk dish"washer" (came with the house, not my choice) was doing okay-ish for a few years. Now it cleans horribly, and this change was rather sudden. There is a nasty white film on all the glasses, the plates feel nasty, and even the tub of the thing isn't clean. I have an obvious rectangle of crunchy white gookus where the big plastic plate is near the door. The inside of the thing is so filmy, I have a hard time refilling the rinse aid, as the little window isn't clear enough anymore to see well. I have a hard time getting the detergent door shut because the latch seems stiff with gookus. Once, I saw some trace of suds (but no water) in the bottom of the tub at the end of the cycle.
I have the rinse aid cranked up, and I'm still using a stash of pre-zero-phosphate Cascade Complete Gel (which I've used for years with no ill effects.) (Yeah I know the Samurai doesn't like gel/liquid; the folks that made our dishes said to use liquid/gel, and I can't convince the wife otherwise.)
Water seems to fill up and pump out just fine, the sink line it drains into does not back up, and there are no error codes.
I have started the process to finally have the recall work done, but I have no idea if this will help the problem.
SirWired
Edited by sirwired, 03 December 2010 - 10:12 AM.
#2 john63
john63
    Dean of LG Appliantology
  • 2,223 posts
Posted 03 December 2010 - 10:29 AM
If the white/clouding on the glassware can be removed with *white vinegar*---too much detergent is being used.
Reduce the amount of detergent *drastically*.
Old detergent loses cleaning effectiveness over time (degrades). Avoid bulk purchasing D/W detergent.
Use DISHWASHER MAGIC to thoroughly clean the dishwasher & try using again with a new detergent.
*Calcium deposit* can also cause the symptoms you've described.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
    Shōgun
  • Master Samurai Tech
  • 31,150 posts
Posted 03 December 2010 - 10:53 AM
Lots of washability complaints coming in since they got rid of phosphates from detergents this summer==> http://fixitnow.com/...ing-detergents/
#4 sirwired
sirwired
    Ikkō-ikki
  • Appliantologist
  • 30 posts
Posted 03 December 2010 - 05:25 PM
Yeah I saw that bit... I thought I was safe since I had a stash of old detergent on-hand. I had no idea that detergents expired! And of course, when they started not getting clean, we added more detergent...
Edited by Samurai Appliance Repair Man, 03 December 2010 - 05:27 PM.
Deleted unnecessary quotation. To reply, scroll down and use the Fast Reply box.
