LG Tromm Electric Dryer DLE7177WM
69 replies to this topic
#21 john63
john63
  • 1,411 posts
Posted 06 December 2010 - 09:08 PM
<<<I didn't mean to make you Mein Gott.>>>
German for "My God!" <<laughing>>
All in good fun.
<<<That seems pretty straight forward but waaay more that two wrenches still. Who gave that rating?? They must have been on a two six pack or something.>>>
<laugh> It seems most "repair manuals" are written by technical people that are not servicers.
As you progress thru your troubleshooting/repair---lean on us. We'll get you thru it.
Good luck!
Edited by john63, 06 December 2010 - 09:09 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#22 RegUS_PatOff
  • 30,219 posts
Posted 06 December 2010 - 10:53 PM
...I guess I was lucky the dryer didn't catch on fire or something...
Posted Image Posted Image
#23 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 December 2010 - 03:46 PM
I have the dryer apart. I am trying to figure out if I am going to get electrocuted. I don't know how hard I can vacuum it - you can see? maybe - I'm not sure if it's attached or not - how severe the dust is. OH - and should I lubricate anything before I put it back together?
#24 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 December 2010 - 03:53 PM
Whoops, that one was a little bigger than I intended - Here's where I'm concerned.
#25 Samurai Appliance Repair Man
  • 24,249 posts
Posted 17 December 2010 - 05:01 PM
Dryer should be unplugged from the wall before you even turn the first screw to disassemble.
Fail to comply and you will fry!
Have a nice day.
#26 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 December 2010 - 05:10 PM
I'm way way past that. It's out in the foyer :smile:
Had to have operating room.
Now I have an URGENT question. I broke one of the Cardinal rules. On the thermostat. Is the Yellow wire on the TOP or the BOTTOM when it is plugged in?
#27 kdog
    RoughShod
  • 7,428 posts
Posted 17 December 2010 - 07:22 PM
Nice pic - can you post one of the thermostat in question?
If it's a thermal disc it shouldn't matter (see if the terminals are labelled c-nc)
#28 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 December 2010 - 08:23 PM
Themostat
I don't see that it's labeled anything.
Here's the service manual. It's part number K560.
Service Manual Page 43
#29 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 December 2010 - 08:30 PM
Should I lubricate any of the drum wheels before i put it back together? Or are they sealed bearings and I shouldn't bother? They look a little rusted around there.
A drop of Slick 50?
#30 RegUS_PatOff
  • 30,219 posts
Posted 17 December 2010 - 08:53 PM
the wiring diagram shows a Red wire on each side of the Hi-Limit Thermostat.
#31 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 December 2010 - 09:06 PM
ummm- no - it's just a big white plug going into the back of it - with two wires coming out of it, one white, one yellow.
#32 RegUS_PatOff
  • 30,219 posts
Posted 17 December 2010 - 09:10 PM
if you're asking, "does it make a difference which way the plug goes onto the thermostat pictured"
the answer is "no".
#33 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 December 2010 - 09:20 PM
Ok, just to make sure we're all on the same page. I'd hate to have to take this all apart again.
I guess I was just over tired by this point. I always take pictures along the way. The minute I unplugged this I knew I had made a major major mistake because I did not document it. It was the last step.
(this is after I have re-installed everything)
Edited by allowingtoo, 17 December 2010 - 09:23 PM.
#34 kdog
    RoughShod
  • 7,428 posts
Posted 17 December 2010 - 10:20 PM
Looks like a go!
#35 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 18 December 2010 - 12:14 PM
Well.;That wasn't it. Now what?
It's still stuck in that same place when I first started.
If you just push the ON Button it says CHECK FILTER.All the other Buttons go to Default time and you can't operate them. Heavy Duty is 54, Cotton Towels is 55 etc.
Edited by allowingtoo, 18 December 2010 - 03:31 PM.
#36 kdog
    RoughShod
  • 7,428 posts
Posted 18 December 2010 - 03:04 PM
Meaning you have to wait to restart motor? can you try and "help" it to start by turning drum while starting (and door switch held closed0
If so you need this :
http://www.repaircli...umber=DLE7177WM
Edited by Samurai Appliance Repair Man, 12 May 2013 - 06:14 PM.
#37 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 18 December 2010 - 03:33 PM
No, when I first started posting it was on it's way out. I ran one load of clothes and it quit permanently.
#38 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 18 December 2010 - 03:42 PM
Took it apart, replaced the Thermistor and Thermostat, vacuumed everything out. Took the little Air compressor to it and blew what I couldn't vacuum out (the motor mostly). Then since I saw some dust up in the Heater element and the Air compressor couldn't blow it out I took that apart and cleaned that out. I did see some burnt dust up in there, so I was glad I did that.
I do have to agree to the 2 Wrench rating. I was a lot easier than it looked at first.
I'm not sure if I have the belt on right though :(
#39 kdog
    RoughShod
  • 7,428 posts
Posted 18 December 2010 - 04:10 PM
Whole belt goes under the idler and then streched over the motor pulley - what is the symptom now ?
#40 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 18 December 2010 - 04:14 PM
It's still stuck in that same place when I first started. Well, second place. First place was it was running and then it quit. Now it is still in the Quit place.
Disassembling an LG Tromm Electric Dryer DLE7177WM
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 06 March 2011 - 11:19 PM
Gott Ein Himmel! Well, ye of little faith, let's grab our "phillips" screwdriver and volt-ohmmeter...
1) Unplug the dryer.
2) Remove 3 "phillips" screws from the TOP COVER of the dryer. These screws...
Read Full Entry →
