LG Tromm Electric Dryer DLE7177WM
#41
Posted 18 December 2010 - 04:18 PM
#42
Posted 18 December 2010 - 06:13 PM
I keep thinking I should go sign up for a class at the local Vo Tech for Electrician. I'd love to learn how to wire stuff up for real. My dad did that for a living - I wish I had gotten him to teach me before he died.
#43
Posted 18 December 2010 - 11:02 PM
I made an error in describing how the THERMAL LIMITER functions in your **electric** dryer.
The electric model LG dryers will CONTINUE to run if the THERMAL LIMITER on the Heater Housing has failed.
The THERMOSTAT on the Blower Housing acts as a "self-resetting" Thermal Limiter for BOTH *gas* AND *electric* LG dryers.
If the THERMAL LIMITER on the Heater Housing fails (on 220v electric models) the dryer will be able to "run" but will not heat.
On GAS model LG Dryers---a failed the THERMAL LIMITER on the Heater Housing will **shut-down** the dryer completely.
Back to your dryer....
Judging from the amount of lint accumulation inside the dryer---this indicates that the venting was very poor indeed.
The MOTOR has *most likely* failed due to extended run times needed to dry laundry and from high-heat exposure caused by poor venting and heavy lint accumulation on the motor.
The inside of the dryer was an "oven" for a l-o-n-g time.
The MOTOR *overload protector* began to shut down the dryer as it became too hot during the cycle.
Edited by john63, 19 December 2010 - 12:30 AM.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#44
Posted 19 December 2010 - 08:49 AM
#45
Posted 19 December 2010 - 11:22 AM
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#46
Posted 19 December 2010 - 11:59 AM
Edited by allowingtoo, 19 December 2010 - 12:00 PM.
#47
Posted 19 December 2010 - 03:32 PM
Yep, you can get 'em - I've seen lots of folks install commercial type machines in their home; bring a very well oiled chequebook when you go shopping though, and expect ALOT of added installation expenses
#48
Posted 22 December 2010 - 01:54 PM
#49
Posted 22 December 2010 - 02:30 PM
"Check Filter" is just a reminder before every Dryer CycleIf you just push the ON Button it says CHECK FILTER.
To test the Motor, use the wiring diagram/diagnostics in the service manual
#50
Posted 09 January 2011 - 11:26 AM
#51
Posted 09 January 2011 - 02:07 PM
#52
Posted 09 January 2011 - 03:16 PM
we took it all apart again, checked the motor - which was OK, put it back together, and the dryer mysteriously fixed itself. Go figure.
#53
Posted 18 January 2011 - 01:45 PM
Is there a picture somewhere on how the dryer belt goes on? I'm still not sure that it's on right. It seems like it's turning slower than it used to. Both belts go under the big wheel and then separate to go around the drum?
#54
Posted 18 January 2011 - 03:17 PM
#55
Posted 18 January 2011 - 05:50 PM
The only way we could get the belt to fit is for both of the belts to go under the wheel on the left. And then they separate - to go around the drum.
But I was just drying a load of clothes and the drum stopped. So something is clearly not right.
#56
Posted 18 January 2011 - 07:31 PM
The portion of the belt that is on the top of the Motor goes around the pulley, and continues to the right around the Drum.
The portion of the Belt on the bottom of the Motor goes directly to the left around the Drum
#57
Posted 18 January 2011 - 10:16 PM
The BELT may need to be checked to verify correct installation.
Also verify that the BELT remains in the groove of the MOTOR PULLEY as well.
Possible failing MOTOR (overheats & cuts-out).
Edited by john63, 29 January 2011 - 11:29 AM.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#59
Posted 21 January 2011 - 03:34 PM
#60
Posted 21 January 2011 - 03:40 PM
Disassembling an LG Tromm Electric Dryer DLE7177WM
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 06 March 2011 - 11:19 PMGott Ein Himmel! Well, ye of little faith, let's grab our "phillips" screwdriver and volt-ohmmeter...
1) Unplug the dryer.
2) Remove 3 "phillips" screws from the TOP COVER of the dryer. These screws...
Read Full Entry →
