LG Tromm Electric Dryer DLE7177WM
69 replies to this topic
#61 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 21 January 2011 - 04:46 PM
There is a flat spot on the belt. DH is convinced he is installing the belt correctly.
#62 RegUS_PatOff
  • 30,698 posts
Posted 21 January 2011 - 04:56 PM
Belt from bottom of Motor Pulley should not touch the Idler Pulley.
Can you post a picture of the "end view" of the Roller ?
#63 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 21 January 2011 - 05:57 PM
hope this works. this is kind of what it looks like when the belt is engaged the way he wants to install it.
#64 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 21 January 2011 - 06:01 PM
once it lifts up, the belt is not touching. That is the only way that amount took up the correct slack of the belt for the drum that we could see.
#65 RegUS_PatOff
  • 30,698 posts
Posted 21 January 2011 - 06:26 PM
looks good
#66 Budget Appliance Repair
  • 4,032 posts
Posted 22 January 2011 - 06:05 AM
Now ya got fingered out!!!!!
You had the belt looped around the wrong side of the idler pulley the first time.
Edited by Budget Appliance Repair, 22 January 2011 - 06:07 AM.
William Burk (Willie)
Eureka, CA 95501
#67 RegUS_PatOff
  • 30,698 posts
Posted 22 January 2011 - 07:01 AM
the first picture was taken from the "back side" of the Pulley :kopkrab:
#68 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 28 January 2011 - 10:30 AM
The first two pictures were taken from above. Then you wanted the "end view" so I took one from the unused back vent hole (since we use a side vent). They were all the same installation, so I'm kind of confused. We didn't change anything that I know of. I don't think.
So what picture were you looking at that you said was installed wrong? The two pictures? Post #61? or Post #63?
#69 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 28 January 2011 - 01:14 PM
OK, we have put it back together for the - what was that? The 4th time?
It sounds better.
Will report back after I dry a load of clothes.
#70 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 28 January 2011 - 06:40 PM
Yay it's working!! Thank you for all of your help.
I also replaced one of the sensor bars along with the new belt - it never occurred to me I would need to order 2 sensor bars - I'm Blond - don't hold it against me. It didn't really need it but it was so inexpensive, I just ordered it anyway. When I did replace it, I found out that underneath it, it was caked up with hard damp lint residue. So I took the other one out and cleaned under it also. My clothes were not drying the last time under the Heavy Duty Very Dry cycle but did dry under the Speed Dry cycle. I think the Heavy Duty cycle is under the sensor side? They were very very damp. This time they dried normal on that side.
Next time I think I'd get the extended warranty. This has been fun but there ought to be a better way to meet new people and learn new things :thanks:
Disassembling an LG Tromm Electric Dryer DLE7177WM
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 06 March 2011 - 11:19 PM
Gott Ein Himmel! Well, ye of little faith, let's grab our "phillips" screwdriver and volt-ohmmeter...
1) Unplug the dryer.
2) Remove 3 "phillips" screws from the TOP COVER of the dryer. These screws...
Read Full Entry →
