Whirlpool Helicopter?
8 replies to this topic
#1 FreshDA9
FreshDA9
  • 3 posts
Posted 12 December 2010 - 09:15 PM
Ok guys me and my brother bought a set of whirlpool washer and dryer for our apartment. i had some cloths to wash and only had 1 laud left of detergent so i put in to big of a load. every since then when it is coming to the end of a cycle it starts banging around real bad kinda sounds like a loader version of a baseball card in a bike spoke or helicopter blades whipping. I can take it apart and fix it but i need a starting point of what to look for and start diagnosing.
Washer is whirlpool LSB6300LW1, type 111, CP3806646
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 15 December 2010 - 08:24 AM
May not need to tear it apart just yet. Lean it back against the wall and look left of center at the back bottom rear of tub. There should be a spring going from the bracket on the tub to the frame of the machine. Do you see it?
    Shōgun
  • Master Samurai Tech
  • 30,956 posts
Posted 15 December 2010 - 10:25 AM
#4 FreshDA9
FreshDA9
  • 3 posts
Posted 17 December 2010 - 08:19 PM
all springs are there. the 1 dampening and the 3 suspension.
#5 nickfixit
nickfixit
  • 2,200 posts
  • Flavorite Brew:Glen Livit
Posted 18 December 2010 - 06:53 AM
Sounds like you have stripped out the basket drive block. It's an easy repair and a cheap part. There should be directions for thr repair posted. I have to go to work, I'll check back when I get home and give you all the details
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 December 2010 - 07:22 AM
... basket drive block. It's an easy repair and a cheap part.
also check the Tabs on the Spin Tube
Druve Block
http://www.repaircli...sp?R=154&N=2858
    Shōgun
  • 30,956 posts
Posted 18 December 2010 - 08:03 AM
Got a video for checking and replacing the drive block on this page==> http://fixitnow.com/...t-drive-washer/
#8 FreshDA9
FreshDA9
  • 3 posts
Posted 19 December 2010 - 02:25 PM
thank you guys. do you think it might be more of a clutch and brake issue vs the drive block? the problem happens when its almost done washing as if there is a brake trying to stop it and it keeps getting pummeled by something? I have it torn down but i need to see if my freinds or family might have a spanner nut wrench. i will post pics of drive block.
#9 RegUS_PatOff
  • 33,588 posts
Posted 19 December 2010 - 04:25 PM
... it starts banging around real bad kinda sounds like a loader version of a baseball card in a bike spoke or helicopter blades...
post YouTube video ?
