1995 Insinkerator Classic Supreme
#1
Posted 19 December 2010 - 02:35 PM
After reading a post on the old "red only" forum, about a guy with a Kenmore that made the same noise, I get the feeling we need a new motor. Should I replace the motor on this unit or buy a new DW? You recommended in that old post that before we rush out a buy something, we ask you, the masters, what you put in your home. Is my Insinkerator better made than the new stuff and worth keeping?
I checked the label inside the unit and the serial number is DK0131149, the model number is shown as CL Supreme.
Your guidance and advice is appreciated
#2
Posted 20 December 2010 - 05:53 AM
One of the best dishwasher of it's time and would be very worth while to keep it going if you can still find the parts for it.
If you only went down to the grinder blade you just need to go a little further and you might just find a small piece of glass or something that needs to be removed.
Once you get it down to all the impellers out and just the motor shaft sticking up if you bypass the door switch by closing the latch handle and pushing a screwdriver in the hole in the top right side of the door and get the motor to run if you still have a noise then most likely the motor because there would be nothing else to make a noise.
The rattling noise may also be the blower motor/wheel that blows air up the dome in the right rear corner of the tub that is only used in the dry cycle. If you only hear the rattling at the end of the cycle when it is drying that would be the thing you would be need to look at.
Edited by Budget Appliance Repair, 20 December 2010 - 05:56 AM.
Eureka, CA 95501
#3
Posted 20 December 2010 - 11:47 PM
Thank you for your advice. You are the second appliance person who has told me to keep this DW as the new ones won't compare. I would like to cut my water use but I have heard the new models won't last as long as this unit.
How do I remove the impeller? I see that the top of the impeller is squared off on two sides, so I use a wrench there, but how do I top the impeller from turning?
Also, my wife wants to change the front color panels, so would I just order based on a KitchenAid model?
Thanks again,
Kurt
#4
Posted 21 December 2010 - 05:59 AM
then post the link here ..
#5
Posted 23 December 2010 - 03:37 PM
Also, which brands and models are recommended if buy a new dishwasher? I am finding few repair shops even know about Insinkerator dishwahers. Your advice is appreciated.
#6
Posted 24 December 2010 - 03:04 PM
Automaticwasher.org has some great pictures too.
Edited by RegUS_PatOff, 24 December 2010 - 03:20 PM.
#7
Posted 24 December 2010 - 03:40 PM
#8
Posted 26 December 2010 - 08:47 PM
You are a life saver. Thank you for the link to the equivalent Kitchenaid DW. Now how do I find a qualified repair guru here in Southern California? Do you think parts are still available? I pulled the unit out of the cabinet today and found that the motor is made by Emerson (Model #S62NXJFR-7233, Part #MS00800017-1). Are these or equivalent parts available?
Thanks much,
Kurt
#9
Posted 26 December 2010 - 09:19 PM
Does the Motor make noise when it's disassembled ?
