Frigidaire range oven issues.
1 reply to this topic
#1 KevinO
KevinO
  • 11 posts
Posted 24 December 2010 - 11:20 AM
I have a Frigidaire range model PLGF389ACC that has gone through a series of symptoms.
At first when set to convection bake it would sit for about 30 minutes preheating before it would get to the temp that was set. When it ignited it would do so with a rumble. After that it would work fine. Now it does not work at all.
Currently when set to just bake it will come on and heat up but after a while there is no more heat (lights are all on normally).
The broiler and stove top work fine.
Does this sound like an igniter or valve problem?
Thanks!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 December 2010 - 11:41 AM
glow Ignitors get weak with age and heat, and will no longer let the Gas Valve open.
http://www.repaircli...p?R=154&N=12872
