GE Profile Dishwasher PDW9700L Broken Again
#1
Posted 24 December 2010 - 04:31 PM
I am hoping that I'll find some more glass fragments below this coarse filter that are causing me problems and get this thing operational again without a more complete disassembly. This stainless steel filter plate is sort of loose on one or two sides, but I hesitate to pry it up from the bottom of the dishwasher and break something. Is there some magic filter release method that GE forgot to describe in the service manual?
If I don't hear any disassembly suggestions in the next couple of days, I'll attack this thing again and report my findings back to the forum. Meanwhile, Merry Christmas!
#2
Posted 30 December 2010 - 05:09 PM
2. Has anyone figured out to improve the filtering performance of this dishwasher so that occasional broken pieces of glassware (or perhaps a large food fragment) will not jam the motor's impeller and impede the water drain function?
#3
Posted 30 December 2010 - 09:26 PM
Edited by SANTA, 30 December 2010 - 09:26 PM.
#4
Posted 01 January 2011 - 05:40 PM
Thanks for your reply. I haven't yet pulled the dishwasher out of its cabinet (sort of a major ordeal getting it out and back into the cabinet due to a lack of clearances). Checking the drain line also requires pulling the dishwasher out from its cabinet, as it drains into a waste pipe that is behind the dishwasher rather than into a garbage disposal inlet to the side of the D/W. Being lazy, I was hoping to be able to access the problem from inside the dishwasher, but I can't figure out how to pull the coarse filter out to check for debris underneath it.
Since I have to go out of town for a bit, this D/W will remain inop for the next two weeks or so. I'll report my findings back to the forum once I operate on the beast.
#5
Posted 01 January 2011 - 11:33 PM
#6
Posted 02 January 2011 - 01:54 PM
Part of my clearance problem and difficulty in removing the dishwasher from the cabinet is that there is a 3/4 inch high board that is screwed and glued to the floor at the bottom front of the kickplate. But I will give your suggestion a try and report back; maybe a little blow with some compressed air through the drain hose will dislodge some glass fragments from the pump housing...
Thanks for your suggestion. I'll see if I can get the drain hose removed/blown out/re-attached with that damn board in place.
Steve
#7
Posted 03 January 2011 - 05:59 AM
Eureka, CA 95501
#8
Posted 03 January 2011 - 11:55 AM
Thanks for that tip. I'll give that a try if I can gain access to the drain line without removing the dishwasher from the cabinet.
Steve
#9
Posted 01 September 2011 - 02:43 PM
Just in time for Christmas 2010, my GE Profile Dishwasher (PDW9700L) has broken again. I suspect it is another broken wine glass that has constipated my drain pump, since the unit will not drain. Prior to complete removal and disassembly of this not-so-well-designed model from its kitchen cabinet, does anyone know how to remove the stainless steel coarse filter at the bottom of the unit? I have a 2006 service manual for this d/w, but it is totally silent on how to remove the coarse filter from inside the unit.
#10
Posted 02 September 2011 - 09:00 AM
That big perforated steel plate? That's a part of the dishwasher basin and can't be removed (without destroying the dishwasher).
FAQs | Parts | Memberships | Consultations | Repair Videos | Newsletter | Beer Fund | Contact
#11
Posted 02 September 2011 - 02:50 PM
I think I would just toss this dishwasher at this point but I have two of these beasts in a big kitchen. When they work, they work great.
