What do you carry?
45 replies to this topic
#1 Tuco
Tuco
    Sōhei
  • Chief Appliantologist
  • 238 posts
  • Flavorite Brew:Tap Water
Posted 24 December 2010 - 06:19 PM
Throw in a bacic rachet with 7/16, 1/2, 9/16 sockets and very long extintion
Edit: Sorry, my first try with a picture, must be some rules that I'm not aware of.
Edited by Tuco, 24 December 2010 - 06:22 PM.
#2 Tuco
Tuco
    Sōhei
  • 238 posts
Posted 25 December 2010 - 02:25 AM
next try
#3 ROBBYRIG
ROBBYRIG
    Senpai
  • PipPipPipPip
  • 635 posts
Posted 27 December 2010 - 03:16 PM
Minimal tools would be phillips, and a 1/4" and 5/16" bits.
you might look a little silly, but those things will get you through most jobs.
#4 LLAMBERT
LLAMBERT
    Yamabushi
  • 91 posts
  • Flavorite Brew:Stone Ruination IPA
Posted 07 January 2011 - 07:10 PM
I carry as little as necessary, but everything I need. Start out with a good size tool box, Soft-sided is a must, much less likely to damage a customer's property. If I don't use a tool at least once a day, It comes out of my carry in bag, and into the truck bag. As it turns out 90% of my daignostic tools would fit in my pockets, however some clients are more impressed by the size of your toolbox than the efficiency and accuracy of your diagnosis, so I compromise and carry a small black cordura tool bag I found in a thrift store for 3 bucks, but your milage may vary.
Why? I came into this game for the action, the excitement. Go anywhere, travel light, get in, get out, wherever there's trouble, a man alone. Now they got the whole country sectioned off, you can't make a move without a form
#5 john63
john63
  • 1,411 posts
Posted 09 January 2011 - 12:02 AM
http://stanleytools....l Organizer Bag
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#6 kdog
    RoughShod
  • 7,428 posts
Posted 12 January 2011 - 01:06 AM
These are nice .... www.VetoProPac.com
#7 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 13 January 2011 - 09:27 PM
my main bag weighs about 60+ lbs. and those are just hand tools, power and specialty tools are in another but all that stays in the truck normally. As Robbie said previously all I normally carry into a home is a meter, 6 in 1 screwdriver, long 5/16 and 1/4 mag. nutdrivers, and a pair of locking cobra pliers. you can pretty much fix anything with those. Why do I have all the other crap you ask? Just in case.....when you 30 miles out in the woods and 10 miles away from anything ya betta be prepared for the worse....trust me, the worse will happen from time to time.
www.eliteapplianceservice.org
#8 john63
john63
  • 1,411 posts
Posted 13 January 2011 - 11:08 PM
<<<trust me, the worse will happen from time to time.>>>
So very true...
Steam vents from both of my ears when I don't have a F*%#K*?G whatchamacallit tool during a service call at the "Outer Limits of Civilization".
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#9 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 15 January 2011 - 11:14 PM
A good tool bag should consist of the following (in my opinion)
These are only the most common tools you will need and does not include
some rarely used, special, or power tools. There are also consumables
that I didn't list like tapes, lubricants, abrasives, terminals, connectors, etc.
long magnetic nut drivers sizes (1/4,5/16,3/8,7/16) and a 3/8 "no magnet" hollow shaft
Stubby nut drivers sizes (1/4,5/16)
6-in-1 or 12-in-1 screw driver (I prefer the 12 cause it"ll hold your T15 and 20 Torx bits)
Small socket set & extra 6" extensions x 2 (1/4 will do for most things...combination set... new whirlpool is metric)
Note: older washers may require 1/2" ratchet tools for inner and outer tub removal repairs
Channel lock or similar type pliers x 2
Hose pinch off pliers x 2 "locking type" (if you only buy one you'll wish you had gotten 2)
a "good" bit set, the cheap ones suck! (with driver) driver utilized as speciality tool
to access some fasteners on refrigerators (wall of driver
head is thinner than a standard 1/4 nut driver)
Wrench set (1/4,5/16,3/8,7/16,1/2,5/8,11/16,3/4) also a stubby 5/8
Wire Strippers and Crimping pliers
small File set
BAS (big ass screwdriver)
not to be confused with a BAH (big ass hammer)
Needle Nose Pliers (regular and long)
Hammer (what ever you prefer, I use different types but in my bag I carry a lil one)
Cutting Chisel
Clamp Pliers (locking type)
Fill Hose Pliers
External Snap Ring Pliers
Tape measure
and Level
Small Tubing Cutter
Sharpie
Linesman
and Vise Grip Pliers
Putty Knife
and Utility Knife
Socket Adaptor 1/4" Female x 1/2" Male
Pick set
Clamp Meter
Temp Gun
Flash Light
extendable mirror
and magnet
Allen Wrench Set
(standard)
Voltage Stick/ Detector
#10 Adirondack Bob
Adirondack Bob
    Sōhei
  • 191 posts
Posted 21 January 2011 - 11:25 PM
I have one of those 60 pounders also. The strap actually leaves red marks on my shoulder. I'm trying to take stuff out of it but I just can't do it. There must a word for this sickness...
#11 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 21 January 2011 - 11:36 PM
I know exactly what you mean...every time i pull something out and don't put it back I usually regret it.
#12 john63
john63
  • 1,411 posts
Posted 21 January 2011 - 11:37 PM
Professional?
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#13 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 21 January 2011 - 11:44 PM
Don't get caught with your pants down
#14 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 27 January 2011 - 06:12 PM
I need to get myself a rolling tool cart for the work I do in these high rise condos. I hate lugging my tool bag and my invoice binder up to the penthouse suites. Sometimes when I get off the elevator I have to walk all the way down the other wing of the building.
Scott Wolf
#15 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 27 January 2011 - 06:52 PM
yeah, you definitely need a rolling box of some sort
#16 RegUS_PatOff
  • 30,254 posts
Posted 27 January 2011 - 06:56 PM
maybe with some type of "spoke" wheels that can use a "real" lock, so that if the (empty) cart is left out in the main hallway / common area,
thieves would have to carry it away.
If not empty, then a good lock also on the drawers, etc ..
#17 Sparky1
Sparky1
    Ikkō-ikki
  • 23 posts
  • Flavorite Brew:Somerset Cider
Posted 19 February 2011 - 01:15 PM
My carry in Kit: Non Contact tester, DMM, Insulation & Loop testers.
Tools: Pliers, Cutters, Snipe nose, Bent snipe nose, Corbin pliers, Slip joint, Pump pliers, 8" Crescent wrench, Terminal Crimper / Strippers.
Set of Insulated drivers, Large driver, Neon Screwdriver, Set of Allen keys, Set of Torx keys, T10/15/20 Torx drivers, Stubby flat & number 2 Philips.
5-13mm Nutspinners plus handle, 8-19mm Short combi spanners, Stanley knife, Capacitor Discharger, Mini Maglite, Comm stick, 2 Short jumper leads, Small file.
Tape, Connectors, Fuses & Cable ties.
All the tools fit neatly into a 16" Nylon box, Weighs about 22Lb in the box & gets me through most things, All the heavy stuff stays in the 4x4 until I need them.
Let us Fix it Properly.
#18 Samurai Appliance Repair Man
  • 24,289 posts
Posted 19 February 2011 - 02:36 PM
You can gaze lovingly upon the Samurai's personal armory here==> http://fixitnow.com/...pliance-repair/
#19 Sparky1
Sparky1
    Ikkō-ikki
  • 23 posts
Posted 19 February 2011 - 04:24 PM
Ahh, Grand Master also has a love of good tools,I see. I also have an identical toolbag but this has other Specialist tools in it, Analogue meters i've allways loved as that was what I was brought up with & allways have 1 in my kit & prefer my Analogue clamp meter to my digital. Unfortunately nowadays I have to use a Digital more & more for some of the stuff I repair so that's what ends up in my carry kit.
Like the Maytag tool roll, how do I get me 1 of those?
The van is cool, wish the inside of my 4x4 was that tidy, may start out like it on a Monday but by Friday it's a mess :D
Don't know what it's like in the US but over here many "Engineers" buy the cheapest of tools & meters. I can understand this maybe when you 1st start out on a limited budget, but not for a professional Engineer.
Edited by Sparky1, 19 February 2011 - 04:40 PM.
#20 J5
J5
    Kohai
  • 320 posts
Posted 19 February 2011 - 06:24 PM
head into a luggage store
i got a little fold up wire based trolley with elastic straps used for travelling
quite small and compact could fit it either behind or under the seat in the truck
and not real expensive
you then use it like those suitcases that the handle pulls out with the 2 wheels
very easy to cart your toolbox along when you need to
something similar to this sort of thing
Edited by J5, 19 February 2011 - 06:26 PM.
