Maytag Bravos Washer MTW6700TQ1 grinding sound in spin cycle
2 replies to this topic
#1 dlb4603
dlb4603
  • 2 posts
  • Flavorite Brew:Whatever you have on hand!
Posted 25 December 2010 - 08:31 AM
Hello and Merry Christmas to all!
I have a Maytag Bravos Washer MTW6700TQ1 and so far it has served me well. I have been noticing this strange sound towards the end of the final spin cycle. Hard to describe but maybe sounds like a rubbing grinding noise. I did some research and from what I had found out is that maybe the Drain Pump assembly had something in it or it was bad. The water was not draining out properly so I had to go on my gut thinking it was the drain pump. I took the back off and took the pump off and sure enough there was one of my wife's nylon stockings caught in the pump. I thought to myself this is awesome and way to easy. Put it all together and ran a load through. Towards the end of the final spin cycle the noise was still there. Not as bad but not a normal sound. I had bought a new pump but have not used it or taken it out of the package which I was told I could return it by my local parts shop. If I spin the drum by hand I don't hear anything abnormal. Wonder if it could still be the drain pump or ....... Thanks for your help and Merry Christmas!
#2 kdog
    RoughShod
  • 7,428 posts
Posted 25 December 2010 - 01:06 PM
With the rear cover off, run the machine in spin - while it's running and you hear the sound, unplug the pump - can the noise still be heard ?
#3 dlb4603
dlb4603
  • 2 posts
Posted 25 December 2010 - 10:21 PM
Thanks kdog! I will try your suggestion and let you know what happens. Thank you again for your reply to my question.
