Warm Amana Refrigerator/Cold Bottom Freezer
5 replies to this topic
#1 Mr.Moron
Mr.Moron
  • 1 posts
  • Flavorite Brew:Hop Valley
Posted 02 January 2011 - 07:03 PM
Hello,
Does anyone have ideas about what to do with an Amana AFD02535DEW french door refrigerator with bottom pullout freezer that has a warm fidge? The freezer is making ice, staying cold. I cleaned the bottom grill, it was caked with fuzz and dust. Not sure what to do. Thanks!
#2 RegUS_PatOff
  • 30,192 posts
Posted 02 January 2011 - 07:16 PM
may need to look at the frost pattern of the Freezer Evaporator Coils
http://fixitnow.com/...ting-flowchart/
#3 kdog
    RoughShod
  • 7,428 posts
Posted 02 January 2011 - 08:15 PM
You could summon the tech sheet from underneath the bottom of the fridge cabinet, behind the front kickplate, upper r.h. side
Perform the test for the motorized damper that is located in the rear of the refrigerator section. Quite common for these units to fail, and somewhere there is a kit to change those over to a better quality damper ass'y.
Double check that model # as it doesn't work for me, and we can provide you a link to the part
#4 RegUS_PatOff
  • 30,192 posts
Posted 02 January 2011 - 09:24 PM
AFD02535DEW
Posted Image My eyesight isn't as good as it once was (see RegUS_PatOff )
but from here it looks like your model number is
. . AFD2535DEW
(mechanical Damper)
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 03 January 2011 - 08:34 AM
i reckon i find the evaporator fan failed on these units more often than the damper, but either way easy diagnosis, easy fix.
access the fan by removing the back wall of frezzer section and test voltage to fan motor...120v but no spin = bad motor
the new motor is redesigned- much more substantial
#6 Robin the Hood
Robin the Hood
    Sōhei
  • Master Appliantologist
  • 183 posts
Posted 03 January 2011 - 06:46 PM
Yup...looks like an AFD2535DEW...
No fan motor spin, no cold air moving from freezer to refrigerator (and back again)...
Something else I see from time-to-time...customers cramming the bottom shelf so full of stuff that it blocks the open damper, and doesn't allow enough cold air to get into Fridge to cool properly...but my money's on the fan motor, here.
"If you want your tree to produce plenty o' fruit, you've got to cut it back from time to time. Same thing with your neural cells. Some people might call it brain damage. I call it prunin'".
