Learn how to be your own tech line...
Sign in to follow this
Followers 0
Budget Appliance Repair
Need Bosch dishwasher help
4 posts in this topic
Bosch Dishwasher
Mod# SHU3305UC/U12
Ser# FD8201 02 0314
Need to know if there is a set limit for the heating cycle in diagnostics in time that if it takes too long to make it up to 150 degrees that will still cause the "Power Scrub Plus" light to lite up, which indicates a heater fault?
In diagnostics it did the following, (thru complete diagnostics "Power Scrub Plus" & "Rinse & Hold" is flashing:
Draining - 30 seconds
Filling - Amps read .01 or less
Heating & Circulating - Water was from an outside cold tap, around 40-50 degrees and heating cycle has to get the water temp up to 150 degrees before it advances to next cycle, was reading 10.0 - 10.8 amps so heater was working and it was raising the water temp by about 2 degrees every minute. Ran for about 1 hour and 5 minutes and then advanced into the last cycle of the diagnostics. As soon as it advanced into drain the "Power Scrub Plus" light stopped flashing and was on solid.
Draining - 60 seconds
Ended with "Power Scrub Plus" light on solid and "Rinse & Hold" light flashing.
Power Scrub Plus light being on at end of diagnostic cycle indicates a Heater fault.
Is the fault from it taking so long to heat the water because the water was too cold to start with, so I have no problems with the machine?
Anyone have any help for me here??????
WOW!!!!! 32 views in two days and no answer????
No one have a clue or this just slip thur the cracks somehow?
Any help would be greatly appreciated guys...................
nothing about it in the service manual ...
Followers 0
