maytag lat8206aae
3 replies to this topic
#1 bruce.b
bruce.b
  • 12 posts
Posted 05 January 2011 - 09:21 PM
My Maytag LAT8206AAE washer's agitator stripped out. The plastic splines inside all wore off and found their way into the washer and the agitator came off the shaft. I don't see any other particular wear on the shaft, and it hasn't been leaking or anything like that. I've seen some posts about the shaft having warn and being loose vertically, but this doesn't seem to be the case. Is there anything else I should check here before I consider going for an agitator? The washer is about 15 years old, and we do a lot of laundry with four kids in the house. If there are going to be other expensive repairs coming soon it might be time to replace.
#2 john63
john63
    Dean of LG Appliantology
  • 2,211 posts
Posted 06 January 2011 - 12:51 AM
A good time to replace the BELTS as well.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 bruce.b
bruce.b
  • 12 posts
Posted 06 January 2011 - 08:03 AM
Thanks. I had an opportunity to look at the belts when I replaced the snubbers several months ago, and they all looked rather nicely tensioned and not terribly worn. I looked a bit further at the splines and things inside the tub later last evening and things don't look worn, and there's no play in the shaft through the drum. I guess I'll presume that 15+ years of usage took its toll on the plastic fins inside the agitator. Once the first one gave out, the stress on the others made short work of them. My wife insisted that the little pieces of twisted plastic from the splines inside the agitator were thread... I knew better, but things didn't become apparent what had gone on until I threw a couple of junk towels in the washer and let it run. When it hit the first spin cycle I heard banging and it stopped out of balance. When I opened the lid, the agitator was lying sideways, and all was apparent... I was just wondering if there were any seals or other parts that were easier to get to while the agitator was out, but it looks to come apart pretty easily, any way.
#4 john63
john63
  • 2,211 posts
Posted 06 January 2011 - 10:58 AM
<<<I had an opportunity to look at the belts when I replaced the snubbers several months ago, and they all looked rather nicely tensioned and not terribly worn.>>>
Limited-slip type belts become "Glazed" (smooth/reflective) over time. This causes more slippage and takes longer for the belts to "catch-up" to the Motor-RPM.
The PUMP BELT should *tensioned* according to the instructions on the package.
<<<I was just wondering if there were any seals or other parts that were easier to get to while the agitator was out>>>
No.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
