Kenmore 80 series 110.92281100
7 replies to this topic
#1 Gluzman Y.
Gluzman Y.
  • 4 posts
  • Flavorite Brew:Pilzner
Posted 11 January 2011 - 11:43 AM
My kenmore UltraFabric Care heavy Duty 80 Series washer model 110.92281100 stoped agitating adn spinning. The motor is working fine, water is filling up and draining fine, only agitation/spinning function is not warking. I suspect it's a belt problem, but not 100% sure. Expert advise will be greatly appreciated.
Y.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
  • Flavorite Brew:Killians Red
Posted 11 January 2011 - 11:53 AM
This washer uses a drive coupling in place of a belt....many how-to instructions on this site for this repair
Does the motor sound like its running but no action in the machine? If so, that is your problem.if no sound, may be a lid switch.
#3 Gluzman Y.
Gluzman Y.
  • 4 posts
Posted 11 January 2011 - 12:28 PM
Thank you! I believe it's a coupling. The motor and switch are fine.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 January 2011 - 12:51 PM
http://www.repaircli...R=154&N=1195967
 (watch help video)
#5 Gluzman Y.
Gluzman Y.
  • 4 posts
Posted 15 January 2011 - 04:17 PM
Well, I replaces the coupling. Found that the old one was still ok. it's agitates (may be I wAs wrong from the start about agitator) but still does not spin. Any further suggestions?
#6 RegUS_PatOff
  • 33,588 posts
Posted 15 January 2011 - 04:57 PM
Does the Washer Motor make any noise when it should be Spinning ?
#7 Gluzman Y.
Gluzman Y.
  • 4 posts
Posted 15 January 2011 - 06:39 PM
There is an usual noise. May be coming from the pump.
#8 RegUS_PatOff
  • 33,588 posts
Posted 15 January 2011 - 08:35 PM
could be something in the Pump
