LG WM2301HW "tE" error code
#1
Posted 11 January 2011 - 01:58 PM
Does anyone know where I can find the thermistor part for the LG WM2301HW? and a place where I can get the manual to open the machine up? Any leads would be greatly appreciated.
#2
Posted 11 January 2011 - 02:22 PM
#3
Posted 11 January 2011 - 02:42 PM
ThermistorIt's mounted to the Heater near the terminals
http://www.repaircli...R=154&N=1377871
May be just a bad connection, but to access the Heater / Thermistor, you must remove the Cabinet Top (2 Screws),
and the Cabinet Front, which involves using a special tool ($25) to remove the Door Gasket Clamp.
There may be another way, when the LG master responds to this thread.
For manuals and lots of other goodies,
become an Apprentice==> http://appliantology.org/apprentice/
#4
Posted 11 January 2011 - 02:59 PM
I just signed up for apprentice. Guess I will just wait for the LG master to respond. Thanks
#5
Posted 11 January 2011 - 03:09 PM
you may be able to, but to flip the Washer onto it's Back,I read in other forums that to access the thermistor, you can just flip the washing machine to its back?
it may be best to re-insert the Shipping Bolts
#6
Posted 11 January 2011 - 04:46 PM
#7
Posted 11 January 2011 - 08:37 PM
On the LG WM2301HW washer---the THERMISTOR is part of the HEATING ELEMENT (not available as a separate part).
Older LG washers had the THERMISTOR mounted through a black rubber seal in the tub assy.
On some washers---the wire at the THERMISTOR is broken. This is located at the front/bottom of the washer tub assy.
Access to the THERMISTOR is best done with the front cover of the washer removed. This allows unfettered access to the THERMISTOR and to repair wiring--if needed.
The wiring can be **hard wired** if necessary (cut the plug off & splice wires only).
On others---the plug connections behind the Control Panel may need a tiny amount of DIELECTRIC GREASE to improve the connections.
If the THERMISTOR *plug* is good & the wiring is not damaged---add Dielectric grease to this plug as well.
THERMISTORS **rarely** fail.
The new *Heating Element/Thermistor Assy* part number is: AEG33121501
<<<We actually tried calling a couple of LG authorized tech and no luck. They claim they know how to fix the machine, charge us a high consultation fee and then don't call us back, ARGH!.>>>
That's pitiful.
Regus wrote:
<<<to access the Heater / Thermistor, you must remove the Cabinet Top (2 Screws),
and the Cabinet Front, which involves using a special tool ($25) to remove the Door Gasket Clamp.>>>
That's correct. Getting the OUTER Door Gasket Clamp *off* is not terribly difficult but it's more of a chore to re-install. The special-tool pliers--makes this effortless.
Edited by john63, 11 January 2011 - 08:49 PM.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#8
Posted 11 January 2011 - 09:47 PM
the closest one I have may be the WM2677
#9
Posted 11 January 2011 - 10:30 PM
However...
The instructions required for gaining access to the front tub of the washer are largely identical for all LG washers dating back to 2003. Most any available manual for the LG washers that have the CONTROL PANEL at the front of the washer will be sufficient.
Some models--as you know--have a *rear* CONTROL PANEL. These instruction are somewhat different & shouldn't be used.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#10
Posted 11 January 2011 - 10:45 PM
link PM'd
#11
Posted 12 January 2011 - 08:16 AM
#12
Posted 12 January 2011 - 08:19 AM
#13
Posted 12 January 2011 - 08:27 AM
#14
Posted 12 January 2011 - 08:41 AM
Thanks, I'll order the heating element part and the clamp. So frustrated at this entire process, I can't wait to rip this thing open
as mentioned above, the Thermistor rarely fails.
It's the wires / connections that go bad.
you won't need the Clamp, but you'll need the special tool to remove / install the Clamp
383EER4001A
http://www.repaircli...R=154&N=1268535
#15
Posted 20 January 2011 - 11:46 PM
Picture of the heating element
Is this the main control panel that I should look to see if theres any disconnect from the heating element?.
Any help would be greatly appreciated.
Edited by namahs, 21 January 2011 - 12:09 AM.
#16
Posted 21 January 2011 - 01:52 AM
Ohm the THERMISTOR to verify within specs.
The HEATER can be ohm'd or a continuity test done to verify if "good".
Removing the HEATER isn't necessary but if desired---pry it out with a flat-blade screwdriver.
The HEATER is mounted in the same manner as a rubber Freeze Plug would be on an engine block. When the 10mm nut is tightened---this causes the rubber seal to expand within the hole in the tub.
I'd skip the MAIN BOARD for now.
Go to the front CONTROL PANEL. Behind it--at the center--are 2 to 3 disconnect plugs. Pull these plugs apart & add a dab of dielectric grease and reconnect.
Edited by john63, 21 January 2011 - 01:53 AM.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#17
Posted 21 January 2011 - 08:12 AM
#18
Posted 21 January 2011 - 11:20 PM
The large cycle selector knob is at the center.
Behind this knob---on the opposite side---there are at least 2 small plugs.
Disconnect the plugs--add dielectric grease (a very small amount) and reconnect.
This should also be done at the THERMISTOR plug.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
