Fisher Paykel DD603 U1 error
#1
Posted 13 January 2011 - 02:04 PM
#2
Posted 21 January 2011 - 12:38 AM
The ECO cycle reduces the temperatures of the washes and rinses, the number of washes and rinses stay the same. I have had temperature related problems on other equipment so suggest you check the inlet hoses particularly around the detergent dispenser unit and he flow through the dispenser..
Ask for a repair manual on the special forum on this site and see how to run the diagnostics for the water supply. You could run this straight after you get the U1 fault.. might tell you something??
As you have swapped the controllers the other difference between the top and bottom drawer is the actual touch pad where you select the program but I cant amagine how his could affect things.
Also make sure water is not syphoning out when it fills. (why it would only do this on third fill i dont know!) Always make sure you have a controller in the bottom drawer otherwise the top drawer does not work.
good luck ..
#3
Posted 21 January 2011 - 05:51 AM
U1 Heavy and Rinse LED
Machine has failed to prime with water within approx. 3 minutes
The water supply is not turned on
The machine is syphoning
The spray arm is not in place
Excessive foaming
The Inlet Valve has failed
The electronic controller has failed
Rotor not fitted correctly
U1 DishDrawer failed to prime with water
within approx. 3 minutes . . . . . . . . . . . . . . . . . . . . . . . . . . Yes . . . . . . .. . . . . . .. . . . . . . . No
1 Is the tap turned on? . . . . . . . . . . . . . . . . . . . . . . .Go to Question 2 . . . . . . . . . . . . . Turn the tap on
2 Is the spray arm in place?
(spray arm may have been
refitted since U1 fault occurred) . . . . . . . . . . . . . . . . . . . . . . Go to Question 3 . . . . . . . . Refit spray arm
3 Activate the water inlet valve in diagnostics.
Does any water enter the machine? . . . . . . .. . . . . . . . . . . . Go to Question 4 . . . .. . . . . Go to Question 7
4 Is the impeller on the rotor slipping? . . . . . . . . . . . . . . . . Replace the rotor . . . . . . . . . Go to Question 5
5 Is the supply water pressure above 30Kpa (4.3p.s.i) . . Go to Question 6 . . . .. . . . . . The DishDrawer requires a minimum water pressure installation of 30Kpa (4.3p.s.i)
6 Are the inlet water hoses and valves
free of any blockages or obstructions? . . . . . . . . . . . . . . . .Go to Question 10 . .. . . . . . . Clear the water valves or hoses of blockage or obstruction
7 Is the resistance of the water inlet valve
measured at the plug on the controller correct? . . . . . . . . Go to Question 8 . . . . . . . . . . .Go to Question 9
8 Is there 24V DC coming from the controller
during the water inlet valve test? . . . . . . . . . . . . . . . . . . . . . . Go to Question 6 . . . . . . . . .Replace the electronic controller
9 Are the wiring and edge connections
down to the water inlet valve okay? . . . . . . . . . . . . . . . . . . . . .Go to Question 10 . . . .. . . . .Replace or repair wiring harness or wiring connections
10 Water inlet valve failure? . . . . . . . . . . . . . . . . . . . . . . . . . . .Replace water inlet valve . . . .Go to Question 11
11 Is the Rotor fitted correctly? . . . . . . . . . . . . . . . . . . . . . . . . Go to Question 1 . . . . . . . . . . . Refit Rotor
The old U3 fault, which indicated a failure to drain i.e. water left in the tub,
will not show up a fault and the DishDrawer will continue through the cycle.
For manuals and lots of other goodies,
become an Apprentice==> http://appliantology.org/apprentice/
#4
Posted 21 January 2011 - 08:46 AM
#5
Posted 21 January 2011 - 07:45 PM
Reading more, Is it true that rinse and fast cycles fill on "time" and the normal cycle relies on the "Hall sensor"? Looking at the parts diagram, the Hall sensor is on the bottom of the drawer?? Anyone know how it senses water level, usually its a float....
I will next switch the hoses and the elec. connectors on the inlet valve and see if that makes any change, and if not then I will suspect the Hall sensor.
THANKS!
#6
Posted 21 January 2011 - 10:45 PM
U1 is a user error fault code. Usually this is caused by having the pressure set wrong in the user options, consult you user's manual. .
thats on 601
i would check the drainage and the tube between the filter inside and the rotor
if its not draining well due to blockage or damaged rotor you can get U1 faults
#7
Posted 22 January 2011 - 12:58 AM
thats on 601
I don't work on these enough to keep this straight. Domo, J5.
#8
Posted 25 January 2011 - 08:09 PM
Archived on: Mon, 19 Mar 2007 21:58:42
MARKETS: NZ, AU, ROW, US, GB, EU, TW, JP MODELS: DD / DS 603 ACTION: All ph3.5 DishDrawers, (ie. products produced since 4 September 2002, UYM 735384 onwards) are fitted with a 2.5 litre/min fill valve. In some rural installations where the water pressure is very low, the product may display a U1 fault because of insufficient water. This can often be corrected by fitting a 4 litre/min valve. Use:
