Thermador Range Broiler Malfunction
2 replies to this topic
#1 panelnut
panelnut
  • 2 posts
  • Flavorite Brew:Sierra Nevada "Celebration"
Posted 23 January 2011 - 09:27 PM
Hi, all, I have a Thermador range mod. no. gsc30cvwc which has a glitch in the broiler controls. The broiler(electric ) is stuck in the "on" mode. Relay problem? Thanks any help appreciated.
    Shōgun
  • Master Samurai Tech
  • 30,518 posts
Posted 24 January 2011 - 10:40 AM
Stuck relay is a very common cause for this problem. You can check by seeing of the relay coil is being energized even with broil is not selected. If no, then the relay is stuck closed. Sometimes, you can free it up by tapping on the relay with a screwdriver handle. Nothing to lose by trying this.
#3 panelnut
panelnut
  • 2 posts
Posted 24 January 2011 - 04:53 PM
Thanks for the info. Do you by chance know the location of said relay? I bought the range out of craigslist and documentation was skimpy.
