JDB8910AWS Jenn-Air Dishwash door Leaking
#1
Posted 23 January 2011 - 09:42 PM
Just did some major repairing to my 10 year old Jenn-Air dishwasher. Put in new motor, pump, filter, thermistor, door seal, drip edge left and right (99002181, 99002182), door seal 99002158 on the bottom. But there is another I don't see in the diagrams that's on the tub.
Anyway - this dishwasher leaked a little bit before, but now it leaks badly at both corners. I read several of the tips and it does sit a tad low in the front. I really don't think the arm assembly is cracked though. I looked fine when I had it out.
The old door seal had about 2 inches extra in each corner unengaged and the new one has about 1/2 in.
I was looking at getting a 'Barrier Control' Number: 99002174
Thoughts?
THANKS
#2
Posted 24 January 2011 - 10:37 AM
#3
Posted 24 January 2011 - 11:52 AM
I actually laid it on its side when I installed the motor. I will check level and square too. Should I plan on the soap dispenser seal too. When I looked under it last night it looked like it was dripping out of the foam, which I think means its leaking from inside the door ?
#4
Posted 24 January 2011 - 11:56 AM
#5
Posted 24 January 2011 - 12:13 PM
Not sure how that vent could even become clogged. I will check it.
THANKS
#6
Posted 24 January 2011 - 12:19 PM
#7
Posted 24 January 2011 - 12:28 PM
Thanks so much.
#8
Posted 24 January 2011 - 01:27 PM
