kitchen faucet
7 replies to this topic
#1 topcat9
topcat9
  • 4 posts
Posted 24 January 2011 - 08:44 PM
I'm in a single family home(2 floors). The sinks and tubs are working on both floors. The kitchen sink has a single handle. Cold water is flowing but no hot water flows through it when the handle is turned up to the left. It's been cold, I'm in N.Y. Could a water pipe be frozen?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 January 2011 - 09:36 PM
Perhaps there's a shut-off under the sink for that faucet ?
Is that sink against an outside wall ?
Does the hot water work at the other faucets on the second floor ?
#3 topcat9
topcat9
  • 4 posts
Posted 25 January 2011 - 08:32 AM
Yes, there is a shut off valve.
Yes, it is.
Yes it does.
#4 topcat9
topcat9
  • 4 posts
Posted 26 January 2011 - 06:32 PM
Thanks. The temperature rose to around 32 degrees and the hot water started working. So I guess it wasn't mechanical.
#5 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 26 January 2011 - 07:22 PM
In these parts we call that a frozen pipe, and just not having water for a couple days is not nearly as bad as what usually occurs - ie. a burst pipe allowing copius amounts of hot water to enter your abode whilst no one is at home. This continues until a) an innocent passerby calls 911 after noticing water leaking out from your basement windows; or :cool: you come home after an extended white knuckle snowy commute to the glorious sounds of rushing water.
Best bet is to locate the area thats freezing and either relocate it or install some good insulation jacket on it.
You can also buy a length of "heat tape" to put on that section of pipe - it is essentially like an extension cord that is attached to the pipe with a thermostat bulb in the end to sense when the pipe is nearing freeze temperature and will activate to keep pipe warm
#6 RegUS_PatOff
  • 33,588 posts
Posted 26 January 2011 - 08:02 PM
... noticing water leaking out from your basement windows
in these parts, we call that an indoor pool :whistling:
#7 kdog
    RoughShod
  • 7,474 posts
Posted 26 January 2011 - 11:48 PM
LOL ! It is HEATED too ......................:thumbsup:
#8 topcat9
topcat9
  • 4 posts
Posted 29 January 2011 - 01:29 PM
Great advice. I will be installing foam pipe insulation asap. Thanks again.
