Carrier 58MXB - replace solenoid, fried my furnace?
tns
I replaced the solenoid valve to the humidifier. I neglected to turn the power off to the furnace. While replacing the solenoid, I may have touched the controlling wires together or to the duct - I saw a small spark at one point. Now the furnace does not operate at all. Any ideas on what I might look at? Thanks.
  • Replies 4
You probably blew the control fuse. At the furnace circuit board look for a 3 or 5 amp automotive type fuse plugged into the circuit board.
Simply replace the blown fuse.
I did find a fuse on the board that looks to be blown and shows open on my ohm meter. The fuse is purple and is only labeled "E". How do I know if this is a 3 amp or 5 amp fuse?
