Kenmore 80 series Dryer keeps going and going
1 reply to this topic
#1 jasseay1
jasseay1
  • 1 posts
Posted 01 February 2011 - 11:17 PM
I've looked and looked and can't seem to find this unique problem. I have a Kenmore 80 series dryer Model 66822690 and the dryer timer keeps running. So my wife ran a load in the dryer; the clothes got dry in a normal amount of time; she took them out and closed the door to the dryer; the timer kept making a clicking noise (like a timer running); minutes later the dryer started back up. when she went in, the timer dial was on the next cycle. she turned around a few times and it kept clicking. basically the only way we can stop the dryer timer from going round and round and round is to keep the dryer door open. When the door is open, you don't hear the clicking.
I've turned to fixitnow.com many times for our Kenmore series 80 washer and now the dryer gets its turn. any help would be greatly appreciated.
#2 RegUS_PatOff
  • 30,213 posts
Posted 01 February 2011 - 11:59 PM
Model 66822690
maybe 110.66822690 ?
Try running the Dryer (Timed Dry Cycles) with the Electronic Control Board removed
IF it then runs OK (Timed Dry Cycles), then bad Electronic Control Board
http://www.repaircli...R=154&N=1060787
IF NOT, then bad Timer
http://www.repaircli...?R=154&N=548375
