Kenmore F1 error code (Oasis)
3 replies to this topic
#1 Uts9000
Uts9000
  • 2 posts
  • Flavorite Brew:single malt
Posted 07 February 2011 - 08:35 AM
My wife (dictator) has laid down the law. Spend my retirement on a new washer!! Please help.... i need to feed my habit----eating
Oasis Kenmore throws F1 error code 20 secs into fill cycle. Have been able to stop and restart. This works, not every time. Un plug and start over. Now, it's doing it during the rinse cycle too. 20 secs into fill F1.
Please help
Stu
    Shōgun
  • Master Samurai Tech
  • 31,139 posts
Posted 07 February 2011 - 10:51 AM
I rectum I'm getting hard o' hearing in my old age-- wanna run that model number by me again, budrow?
Here's some dejevue fer ya:
Your Attention Please
When starting a new topic, please be sure to include your complete model number. For model number help, please see this page.
For manuals and lots of other goodies, become an Apprentice==> http://appliantology.org/apprentice/
#3 Uts9000
Uts9000
  • 2 posts
Posted 07 February 2011 - 10:57 AM
oops
110 27072603
    Shōgun
  • 31,139 posts
Posted 07 February 2011 - 11:04 AM
Looks like you won the grand prize! F1 is the error code for a bad controller. But there's a service flash out on this with some other things to check before replacing the controller:
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed.
A. Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B. Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C. Lintorflashingintheairdomehoseconnectionport.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub.
D. The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues with the air pressure system.
Part link for the controller, if needed==> http://www.repaircli...-Module/1469076
