simpson delta
2 replies to this topic
#1 paul woolley
paul woolley
  • 5 posts
Posted 25 April 2005 - 01:10 AM
Simpson Delta washer  agitator spins when barrel should  on drain cycle does anyone have a possible solution to this problem
  • 24,307 posts
Posted 25 April 2005 - 10:15 AM
I doubt anyone here has heard of Simpson Delta, much less worked on one.  But if you post or fax the wiring diagram/ tech sheet we'll help you troubleshoot it.  My fax number is 775-416-4449.
#3 Mad Mac
Mad Mac
  • 1,432 posts
Posted 25 April 2005 - 04:19 PM
A quick Google would appear to indicate that Simpson Delta is the "Thunder From Down Under", turning up a lot of .au and .nz sites. I'm up for it if we can get a wiring diagram!
Mad Mac....Pray to God he's out there....somewhere.
