LG Dryer DLE2514W Does not spin
51 replies to this topic
#21 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 16 February 2011 - 11:47 PM
think that has anything to do with it-meaning the vent hose has changed position.
Quite possibly, try it for a bit with vent disconnected and see what happens
#22 neehowhenhow
neehowhenhow
    Sōhei
  • Chief Appliantologist
  • 118 posts
  • Flavorite Brew:Pete's wicked
Posted 18 February 2011 - 07:46 PM
we're going to try that - I am able to override the "sensor" function of the dryer and use a time period for drying- the heater kicks on for that. It would be nice to have this sucker workin right, though. Thanks for your post!
I embrace that which I cannot change...
Housework RULES!
#23 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 04 March 2011 - 05:11 PM
no dice- still lights up- we took the dryer apart, cleaned the temp sensors, ran the diagnostic test which was bizzare as the readings didn't match the service manual readings. (gonna try that again). I can run the dryer on timed drying and get results, but not from sensor drying.
any other thoughts?
thanks!
Housework RULES!
#24 john63
john63
    Dean of LG Appliantology
  • 2,228 posts
Posted 04 March 2011 - 10:19 PM
If the dryer vent from the rear of the dryer to the outside vent hood is absolutely/positively clean/clear without a doubt...
I would test the THERMISTOR ohms (on the blower housing).
I've never had one fail---yet.
If the THERMISTOR is within "spec"---replace the MAIN BOARD.
How long does it take the dryer to *dry* laundry in Timed Dry Mode?
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#25 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 05 March 2011 - 03:25 AM
takes about 120 min, I have to run the 60 min timed dry twice.
Thanks for the post- will check!
Housework RULES!
#26 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 31,377 posts
Posted 05 March 2011 - 08:03 AM
Parts links for :
Thermistor==> http://www.repaircli...Number=DLE2514W
Main circuit board==> http://www.repaircli...Number=DLE2514W
#27 john63
john63
  • 2,228 posts
Posted 05 March 2011 - 09:34 AM
<<<takes about 120 min>>>
That is an indication of a partially restricted/block exhaust vent.
If the venting is in the wall/ceiling of the home---having a professional vent cleaning company clean/clear it--is recommended.
However---if you have an electric lawn/leaf blower---you can try *blasting* air through the vent first.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#28 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 17 March 2011 - 10:17 PM
we're going to try the blower idea, then move on to replacing parts- this machine still has the hiccups.
thank you so much for your help guys!
Housework RULES!
#29 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 31 March 2012 - 07:12 AM
sorry to raise this thread from the dead, but still battling this beast. We replaced the thermistor...still not working right, constantly on the "Cooling" stage, whether I use a program to dry, or force it with timed drying. the blower thing wasn't successful either. we did replace the silver accordion vent and cleaned the crap out of everything "dryer". No dice.
Any thoughts? thanks for your help!
Housework RULES!
#30 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 881 posts
  • Flavorite Brew:yeunling
Posted 31 March 2012 - 09:47 AM
did you try running the dryer without the vent hooked up?
#31 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 31 March 2012 - 11:19 AM
Ooooo.... goona try it!
Housework RULES!
#32 clman_old
clman_old
    Sōhei
  • 144 posts
  • Flavorite Brew:Abita Amber - 2nd to Crown n Coke
Posted 03 April 2012 - 01:33 PM
Did you get this resolved?
25 Years in the biz. 9 years LG authorized.
#33 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 04 May 2012 - 11:30 AM
So very sorry to have not replied...5 kids, 1 dog and chaos 24/7. No this bad boy is still very naughty, we have done all the suggestions, and even replaced the little doppleganger thingy- to no avail.
thank goodness for the summertime and the clothes line, but this has to get fixed! any other ideas? I soooo want to get a 20 yr old top load scratch and dent from sears.
Housework RULES!
#34 kdog
    RoughShod
  • 7,474 posts
Posted 05 May 2012 - 12:33 AM
#35 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 08 May 2012 - 12:56 PM
I didn't try that? thought I did. I will right now and let you know. thanks!
eta...I did try running it without the vent hooked up- that was the last thing I tried. I'll try it again. :)
Edited by neehowhenhow, 08 May 2012 - 01:00 PM.
Housework RULES!
#36 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 24 August 2012 - 07:11 AM
arise dryer thread!!!! no dice, still not working right, must override and run the sucka hot. still not working. uggh. whatcha think?
Housework RULES!
#37 Samurai Appliance Repair Man
    Shōgun
  • 31,377 posts
Posted 24 August 2012 - 07:55 AM
This topic has gotten so long in the tooth that it would be helpful if, at this time, you posted a summary list of all the actions you've taken to try and solve this problem since starting this topic.
#38 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 08 March 2014 - 08:44 AM
Hello again. I will try to summarize what we have done for the dryer- but we have a new problem.
I can power it on, but I cannot choose a dryer option. The lights flicker and it does not run. Like it cant choose a mode. I cant make it run!
Electronics? Anyway to override it? Probably need a new control panel?
We also have a surge of field mice moving in!!!
As far as what I have done with the dryer- we have replaced the belt, replaced the thermistor, cleaned the filter, and exhaust hose. We have ran it w/out the hose hooked up.
Still not working. The only way I can get it to work, is to use the timed dry 2 times to get anything dry. And not on high- or it will set on fire it gets sooo freaking hot!
But now- the control panel is wiggin out.
If you can help, please do- even to recommend replacing the control panel...( is this it??? Main circuit board==> http://www.repaircli...Number=DLE2514W   )   (Maybe it will be the ultimate fix!)
thanks!
aj
Housework RULES!
#39 john63
john63
  • 2,228 posts
Posted 08 March 2014 - 09:48 AM
Press and hold the MORE AND LESS buttons
Press the POWER button and release all 3 buttons
Do all of the Control Panel LEDs illuminate?
Edited by john63, 08 March 2014 - 09:49 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#40 neehowhenhow
neehowhenhow
    Sōhei
  • 118 posts
Posted 08 March 2014 - 09:53 AM
Okay, pressed the buttons:
Display shows: U01, then 18H0 flickering back and forth- all lights light up and flicker.
Housework RULES!
