Advantium 220 microwave electrical burning smell
24 replies to this topic
#1 ibis81
ibis81
  • 15 posts
Posted 10 February 2011 - 12:54 PM
When I use my Advantium microwave function for a minute or so it begins to emit a burning electrical smell. It seems to come out the exhaust under the microwave. Any idea on how to troubleshoot?
  • 24,239 posts
Posted 10 February 2011 - 04:43 PM
Hard to troubleshoot a smell. About the best you could do is to open her up and have a look at the guts, looking forward discoloration, scorching, and paying particular attention to any burned solder joints on the back of the circuit board.
#3 ibis81
ibis81
  • 15 posts
Posted 14 September 2011 - 03:06 PM
I had opened it and checked everything. It all looked ok so I put it back together. Fast forward six months and I now have a dead advantium. I opened it up again and the line fuse holder is melted on the bottom half.
I have read that a fault by one of the latch sensors will cause the line fuse to be intentionally shorted. Is that correct? If so, would it melt the holder? Should I start with those or are there other trouble shooting steps I should take first.
#4 RegUS_PatOff
  • 30,213 posts
Posted 14 September 2011 - 03:21 PM
... have read that a fault by one of the latch sensors will cause the line fuse to be intentionally shorted.
... Fuse would blow instanly ..
wouldn't cause an "electrical burning smell"
For service manuals and other perks,
http://appliantology...-special-perks/
#5 ibis81
ibis81
  • 15 posts
Posted 14 September 2011 - 03:58 PM
Thanks for the quick response. Any other guidance on where to start?
I will check out the membership when I get home.
#6 RegUS_PatOff
  • 30,213 posts
Posted 14 September 2011 - 05:32 PM
could be a bad HV Diode, HV Capacitor or bad Magnetron
31-9038
link PM'd
#7 ibis81
ibis81
  • 15 posts
Posted 14 September 2011 - 10:00 PM
Ok. I suspect the smell was caused by the melting plastic fuse holder.
I did a visual inspection of the diode and capacitor. Both show no signs of any problem. I'll check them with an ohmmeter tomorrow.
Any idea where I can find instructions on testing the magnetron?
#8 RegUS_PatOff
  • 30,213 posts
Posted 14 September 2011 - 11:29 PM
... did a visual inspection of the diode and capacitor. Both show no signs of any problem.
if bad, they won't show any visual indications
#9 ibis81
ibis81
  • 15 posts
Posted 17 September 2011 - 04:16 PM
So I tested the diode and the capacitor. It looks like the capacitor is ok but the diode seems to be faulty. At least thats what my very rusty multimeter skills indicate. The when I test the cap in one direction it reads infinity. When I switch it it reads negative and then returns to infinity. I think that is what it's supposed to do. Please confirm.
The diode shows infinity in both directions.
If it is the diode should I check anything else that would have made it fail?
Also should I also check the magnetron? If so how do I do that?
Edited by ibis81, 17 September 2011 - 04:17 PM.
#10 RegUS_PatOff
  • 30,213 posts
Posted 17 September 2011 - 04:27 PM
... reads negative and then returns to infinity.
... he diode shows infinity in both directions.
1) yes
2) Diode is probably OK, usually shorts when bad.
use a 9v battery in series and test for voltage
forward = some voltage
reverse = 0 v
#11 ibis81
ibis81
  • 15 posts
Posted 17 September 2011 - 04:40 PM
Yep. Sure enough the diode shows voltage in only one direction.
I found some instruction on testing the magnetron. It reads ~.9-1 ohm across the terminals.
#12 Samurai Appliance Repair Man
  • 24,239 posts
Posted 17 September 2011 - 06:25 PM
Only thing left is the HV transformer. Test the primary and secondary windings. Look for discoloration around it, too.
#13 Budget Appliance Repair
  • 3,998 posts
Posted 18 September 2011 - 05:47 AM
Disconnect the two wires going to the magtube and set it for 20-30 seconds and run it. If no abnormal noises and no smell with magtube disconnected, (MAKE SURE BOTH WIRES THAT ARE DISCONNECTED FROM THE MAGTUBE ARE SAFELY AWAY FROM EVERYTHING AND MAKE SURE NOT TO GET NEAR THEM!!!!!!!), the most likely problem is a bad magtube.
If you short the capacitor, carefully with an insulated screwdriver after doing the above test and it sparks you can be pretty sure
the magtube is bad also.
If everything else checks OK and the smell is kind of a sweet plastic burning smell, (I don't know how else to explain it but once you've smell it once you will know for sure the next time), then it's for sure a bad magtube.
William Burk (Willie)
Eureka, CA 95501
#14 ibis81
ibis81
  • 15 posts
Posted 18 September 2011 - 11:23 AM
I tested the hv transformer. These are the results.
Between primary leads -1.2 ohms
Between filament leads - 1.2 ohms
Between tap and chassis - 65 ohms
between filaments and chassis - infinite
I can't do this because the line fuse has blown. I'm afraid if I replace it to test this it will just blow again.
#15 RegUS_PatOff
  • 30,213 posts
Posted 18 September 2011 - 12:11 PM
... I can't do this because the line fuse has blown.
#16 ibis81
ibis81
  • 15 posts
Posted 18 September 2011 - 12:48 PM
Ok I'll pick those up. Do the results of the hv transformer tests seem correct? Another site I saw said the readings on the filaments and the primaries should be significantly below one ohm.
#17 RegUS_PatOff
  • 30,213 posts
Posted 18 September 2011 - 03:22 PM
... the readings on the filaments and the primaries should be significantly below one ohm.
yes, as shown in the 31-9038 service manual
#18 ibis81
ibis81
  • 15 posts
Posted 18 September 2011 - 04:40 PM
I guess what I am asking is what are acceptable tolerances?
In you opinion are the readings I took significantly different to indicate a problem that would cause the original problem?
Should I go ahead and perform the test BAR suggested anyway?
#19 RegUS_PatOff
  • 30,213 posts
Posted 18 September 2011 - 05:58 PM
... are the readings I took significantly different to indicate a problem
... Should I go ahead and perform the test BAR suggested anyway?
1) may depend on your meter..
2) that may be the easiest ..
#20 ibis81
ibis81
  • 15 posts
Posted 19 September 2011 - 04:43 PM
So i did the test outlined. I ran the microwave with the magnitron disconnected. Everything seemed to run fine.
After I did the test. I unplugged everything. When I shorted the capacitor it did not appear to have held a charge, nothing at all. Is there anything that could account for that?
The Willie Method ™ for testing a microwave oven magnetron tube
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 18 September 2011 - 06:50 PM
Sometimes, when you're troubleshooting a microwave, it can be tricky to tell whether or not the magnetron tube is bad. In the case with many GE microwaves, the magnetron can test good according to the filament resistance specifications yet fail when you're actually trying to get the damn thing to heat up your bagel.One of the outstanding Master Appliantol...
Read Full Entry →
