Washer leaks
1 reply to this topic
#1 alonerep
alonerep
  • 1 posts
Posted 25 April 2005 - 03:36 AM
I read a post about Kenmore washer leaking. I have the same problem and I check the pump and it looked ok without any rust on the shaft or water stain on the pump. The leak is on the same side as the pump and the suggestion that the bleach dispenser may be at fault. How do I get to replace or inspect it if there is any leak there? Can I just remove the top part of the cabinet without having to remove the whole cabinet?
alonerep
#2 FatMan
FatMan
    Sōhei
  • Master Appliantologist
  • 233 posts
Posted 25 April 2005 - 05:50 AM
Sorry but you have to remove the whole cabinet. Didn't you do this before when you inspected the pump?
