Whirlpool Duet GEW9250PW0
6 replies to this topic
#1 goldwing78
goldwing78
  • 3 posts
Posted 13 February 2011 - 07:49 PM
I have ran several diagnostics and the thermal fuse looks to be out. (infinate resistance) and running the motor circuit test I get 2.9 ohms with the thermal fuse in and 2.2 with it disconnected and the two blue wires held together. The tech sheet says replace the machine control if the ohms are between 1-6. With the thermal fuse being out, should I just try replacing the $10 fuse or go ahead and order the much more expensive electronics control board? Any advice would be great. The wife wan't the dryer working again in short order.
#2 nickfixit
nickfixit
  • 1,966 posts
Posted 13 February 2011 - 08:08 PM
Did you try just test running the dryer with the thermal fuse bypassed?
#3 goldwing78
goldwing78
  • 3 posts
Posted 13 February 2011 - 08:30 PM
Nickfixit ---You rock! I didn't try bypassing the fuse. After you suggested it I said a Homer Simpson "DUH" and tried it. I'm back in business and my wife is ever greatfull..
Thanks for the help!
  • 24,360 posts
Posted 13 February 2011 - 08:40 PM
But don't keep running it that way cuz you may end up with a house like this:
The Heartbreak of Home Dryer Fires by Zenzoidman, on Flickr
Dryer Fires are Easy to Avoid! by Zenzoidman, on Flickr
Thermal fuses usually blow because of bad dryer vents: too long, too many kinks, made of all flex hose, plugged exhaust hood, etc. Fix the vent problem and replace the thermal fuse==> http://www.repaircli...mber=GEW9250PW0
#5 goldwing78
goldwing78
  • 3 posts
Posted 13 February 2011 - 09:08 PM
I've got the fuse on order. Going to finish 1 load with it bypassed. Hopefully be back in business by Tuesday.
#6 RegUS_PatOff
  • 30,296 posts
Posted 13 February 2011 - 09:10 PM
http://applianceguru...rum2/26362.html
#7 RegUS_PatOff
  • 30,296 posts
Posted 13 February 2011 - 09:13 PM
don't leave the Dryer un-attended
