fisher & paykel dd602 beeps
2 replies to this topic
#1 davej
davej
  • 1 posts
Posted 17 February 2011 - 10:32 AM
fisher & paykel dd602 problems . Previously had the U fault with not enough water. Replaced water valve all ok. Now doing it again.Doubt if its the valve again.Any suggestions? Service manual would be very helpful if its available
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 February 2011 - 12:30 PM
the U fault
Now doing it again.
U1 Heavy and Rinse LED
Machine has failed to prime with water within approx. 3 minutes
 The water supply is not turned on
 The machine is syphoning
 The spray arm is not in place
 Excessive foaming
 The inlet valve has failed
 The electronic controller has failed
 Rotor not fitted correctly
For manuals and lots of other goodies,
become an Apprentice==> http://appliantology.org/apprentice/
    Shōgun
  • Master Samurai Tech
  • 30,534 posts
Posted 17 February 2011 - 08:06 PM
Could be gookus or sediment caught in the inlet valve, too. Posted Image
