GE #WSXH208F0WW
#1
Posted 19 February 2011 - 02:15 PM
#2
Posted 19 February 2011 - 02:32 PM
Use needle nose pliers to release the retaining spring from around the bellows. Peel back the bellows on the door switch side. Reach in and hold the door switch while you unscrew it. Pull the switch out through the bellows, remove wire harness connectors, install new switch in reverse order. Ten minute job IF everything goes wrong. Piece of pie, tovarish!
Can we do it?
#3
Posted 19 February 2011 - 08:49 PM
