Whirlpool dryer GEW9260PLO wont start
1 reply to this topic
#1 welchs101
welchs101
  • 1 posts
Posted 21 February 2011 - 03:29 PM
Hi, my friends dryer is not working. He thinks he knows what is wrong.....he thinks its one or both of the following parts went bad
T9AS1D12-12
T9AS1D22-12
My questions are these
1) For the T9AS1D22-12 part there are two quick connect pins on top of the device which when i put an ohm meter across them they read "infinite"......i can find the data sheet for this part (simply goto mouser or digikey and look up part) however, i cant tell from the data sheet what the measurement should be.
2) For the T9AS1D12-12 part there is no top side measurements.......only bottom measurments on the underneath of the pcb board. What measusrements can i do on this part to see if its working correctly?
thanks.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 21 February 2011 - 04:00 PM
what's "not working" ?
No Drum rotation ?
No Heat ?
Those are Relays, and depending on your symptoms, may or may not be your problem.
