FAQs | Store | Memberships | Repair Videos | Newsletter | Beer Fund | Contact
Frididaire dishwasher fdb658rac1 - Sticks in rinse cycle
14 replies to this topic
#1 jeffross
jeffross
  • 8 posts
  • Flavorite Brew:molson
Posted 21 February 2011 - 07:54 PM
I have a Fridgeaire fdb658rac1. When it reaches the Rinse cycle, it gets stuck at this point and will not advance. When I turn the knob to the Dry cycle, the dishwaher completes the cycle. It does appear to operate normally in advance of the Rinse cycle..ie when initiated Noraml wash it advances at a normal pace up to the Rinse and then gets stuck as noted above. Is this the Timer for certain ? Is there anyway that I can troubleshoot to determine the exact cause ?
Thx in advance
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 21 February 2011 - 08:54 PM
may be a problem with the Heater, or Thermostats.
Is there "hot steam" when the Door is opened after a completed Wash Cycle ?
Try a Wash Cycle with the Hi-Temp Wash OFF and the Sanitize OFF
#3 jeffross
jeffross
  • 8 posts
Posted 21 February 2011 - 09:12 PM
Thx for the reply, yes there is hot steam after the wash cycle. There is also hot air during the rinse cycle as well
#4 RegUS_PatOff
  • 33,588 posts
Posted 21 February 2011 - 09:21 PM
see if it will complete a Cycle
#5 jeffross
jeffross
  • 8 posts
Posted 22 February 2011 - 10:46 AM
Thx for the feedback, will try nxt week-end when I am back home.
#6 jeffross
jeffross
  • 8 posts
Posted 27 February 2011 - 06:43 PM
Tried this with the Try a Wash Cycle with the Hi-Temp Wash OFF and the Sanitize OFF and the cycle did complete itself.
Would this mean that I have a faulty thermostat ?
When the dry cycle ran, there was steam coming out of the vent on the front of the control panel
#7 RegUS_PatOff
  • 33,588 posts
Posted 27 February 2011 - 08:04 PM
could be
maybe either one of these
http://www.repaircli...db658rac1-==c24
#8 jeffross
jeffross
  • 8 posts
Posted 28 February 2011 - 11:02 AM
Thx for the guidance...is there anyway that I could troubleshoot to ascertain which thermostat might be the culprit ?
Thx in advance
#9 RegUS_PatOff
  • 33,588 posts
Posted 28 February 2011 - 02:30 PM
If you have a meter to test them,
the bad one may be "open" at room temperature
#10 jeffross
jeffross
  • 8 posts
Posted 28 February 2011 - 10:08 PM
Ok, I note that the wiring diagram highlights the location of the thermostat...but not the hi-limit thermostat. IS the hi-limit thermostat the same as the hi-temp wash thermostat.
The parts manual notes the following, in addition toi the basic thermostat:
154227807 Thermostat,temp hotrinse
154227808 Thermostat,temp boost
Do you haved a drawing that notes the location of these additional thermostats so that I can check them as well
thx in advance
#11 kdog
    RoughShod
  • 7,465 posts
Posted 28 February 2011 - 11:04 PM
Hi limit is located right beside the heating element connector
#12 RegUS_PatOff
  • 33,588 posts
Posted 01 March 2011 - 04:24 AM
5995374476.pdf
#13 jeffross
jeffross
  • 8 posts
Posted 01 March 2011 - 07:53 PM
Thx for the diagram, the hi limit theromstat is not located on the drawing. I suspect that this would be in the vicinity of the heating element and close to the location of the thermostat. I am going to check to see if there are any char marks that might indicate a malfunction. I do not have an ohmeter to test the circut
#14 kdog
    RoughShod
  • 7,465 posts
Posted 01 March 2011 - 08:02 PM
Those don't usually show any obvious failure other than continuity, some are resettable (have red button) -
Try running it in dry part of the cycle with the heated dry selected and see if the element heats up
#15 RegUS_PatOff
  • 33,588 posts
Posted 01 March 2011 - 08:40 PM
from a maybe similar model:
Replace Thermostat
1. Disconnect dishwasher from electrical supply.
2. Remove outer door panel. (See Remove Outer Panel.)
3. Remove screw holding retainer over thermostat.
4. Remove wires from thermostat.
Remove Outer Door Panel
2. Open door and remove two bottom screws from both sides of outer door panel.
Hold panel as screws are removed.
3. Close door and pull bottom of outer door panel away from door as you pull down on outer door panel.
