whirlpool gas range mod. SF362LXSB
2 replies to this topic
#1 moon13
moon13
    Sōhei
  • Chief Appliantologist
  • 207 posts
Posted 22 February 2011 - 03:56 PM
No bake, no broil. Continuity was not present between the common terminal and the bake terminal. This = new valve. Does the gas valve control the spark ignition? When I set the oven for bake or broil, there is no "snapping, ticking" of the spark ignitor. Is this common when the valve is faulty?
#2 RegUS_PatOff
  • 30,266 posts
Posted 22 February 2011 - 05:00 PM
. . . Is this common when the valve is faulty?
yes, with Oven DSI Spark Modules, neither Bake nor Broil will Spark if either portion of the Gas Safety Valve has no continuity.
#3 moon13
moon13
    Sōhei
  • 207 posts
Posted 22 February 2011 - 06:05 PM
thanx for the quick reply REG. This is the first DSI I have seen, so I wasnt sure about that fact. Thanks again.
