KENMORE STACKABLE WASHER WONT DRAIN OR SPIN
9 replies to this topic
#1 RAL1
RAL1
  • 5 posts
Posted 23 February 2011 - 06:31 PM
MY WASHER WILL FILL AND AGITATE BUT WONT DRAIN OR SPIN IN ANY CYCLE STACKABLE WASHER DRYER COMBO --- MODEL NUMBER washer # 41794812301 date 3-04 serial# XE41103525
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 23 February 2011 - 07:04 PM
Frigidaire Kenmore 41794812301
How's the Lid Switch ?
http://www.repaircli...?R=154&N=916791
#3 RAL1
RAL1
  • 5 posts
Posted 23 February 2011 - 07:07 PM
I TRYED JUMPING THE SWITCH BUT IT HAS THREE WIRES TRYED ALL THREE - NOTHING
#4 RegUS_PatOff
  • 33,588 posts
Posted 23 February 2011 - 07:19 PM
During the first 12 minutes of the Wash Cycle, does the Timer Advance ?
    Shōgun
  • Master Samurai Tech
  • 30,703 posts
Posted 23 February 2011 - 07:39 PM
Check the lid switch plunger attached to the underside of the lid. If you don't see one, that's the problem.
#6 RAL1
RAL1
  • 5 posts
Posted 24 February 2011 - 06:19 PM
the plunger is there -- ran wash cycle ran for exactly 12 min and stoped - timer did advance any other ideas ?? - thank you so much
#7 RAL1
RAL1
  • 5 posts
Posted 24 February 2011 - 06:21 PM
o sorry and i thought the switch had 3 wires and i was wrong it has 4 wires - tryed jumping them but no luck
#8 RegUS_PatOff
  • 33,588 posts
Posted 24 February 2011 - 06:56 PM
. . ran wash cycle ran for exactly 12 min and stoped - timer did advance
I wasn't thinking right . . .
If it Agitates, the Lid Switch is good.
Looks like a bad Timer
http://www.repaircli...R=154&N=1014374
#9 RAL1
RAL1
  • 5 posts
Posted 24 February 2011 - 07:08 PM
(thank you )very much ill give it a try
#10 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,047 posts
Posted 25 February 2011 - 07:34 AM
It could agitate and still be a bad lid switch.
This is the newer style Frigidaire lid switch with the agitate switch being the micro switch attached to the outside of the switch. It is labeled as lid switch on the diagram, if this switch is bad it won't agitate.
The spin lid switch and lid lock bi-metal is the two contacts coming out the side of the main lid switch housing and is labeled as lid lock on the diagram. If this section of the switch assembly is bad it won't spin. It's not an uncommon problem to have the bi-metal that activates the lid lock arm break loose from it's spot welds to the terminals inside the housing assembly.
William Burk (Willie)
Eureka, CA 95501
