Kitchenaid D/W KUDP02CRBS2
7 replies to this topic
#1 Zbates
Zbates
  • 5 posts
Posted 24 February 2011 - 07:58 AM
The unit will stop during wash cycles and the start/resume button will flash. You can then press the swart/resume button and the unit will then continue washing. It may do this several times during a wash cycle. If you use the Normal wash cycle with Heated dry option it will complete it's cycle as designed. If you use the Sani rinse option at anytime it will stop during the wash cycle. It will also stop on Heavy duty wash cycle.
It has had multiple overlay panels, control boards, door switches and soap dispensers replaced. The problem has not been resolved yet for more than a few weeks. This issue has been going on for more than 2 years.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 February 2011 - 08:01 AM
has the Door Latch been inspected ?
Are the symptoms the same if you were to open the Door ?
