Kenmore (Frigidaire) upright freezer - blinking light
#1
Posted 27 February 2011 - 08:58 PM
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2
Posted 27 February 2011 - 11:34 PM
#3
Posted 28 February 2011 - 07:13 AM
706-778-3411
#4
Posted 02 March 2011 - 06:47 AM
On most freezers, a blinking light means the box is warming up. Check the usual stuff: door seal, door left ajar, compressor running, light stuck on. This is an autodefrost unit, too, so make sure the defrost system is working, check evaporator frost pattern. And make sure the evap fan is running, too.
#5
Posted 02 March 2011 - 03:21 PM
FFU20G9FW1 Owner's Guide
Temp Alarm (some models)
This feature is designed to provide a warning if the inside temperatures reach an unsafe level.
When the freezer is initially plugged in, the red Temp. Alarm Indicator Light blinks.
The indicator light will continue to blink until the freezer has reached a safe freezing temperature.
If a malfunction causes an unsafe temperature inside the freezer, the red light will blink and the buzzer will sound.
To silence the buzzer, press the ALARM OFF button.
The Indicator Light will continue to blink until a safe freezing temperature is again reached.
If the ALARM OFF button is not pressed, the buzzer will turn itself off automatically after 48 hours,
but the red Temp Alarm Light will continue to blink.
#6
Posted 02 March 2011 - 03:37 PM
#7
Posted 02 March 2011 - 03:41 PM
. . . his model is the "older style" FrigidaireYour freezer may have a 9volt backup battery
