Moving a SubZero 532
15 replies to this topic
#1 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 01 March 2011 - 03:12 PM
looks like mine was made before roller assemblies became standard. march 1988 manufacture date. am i faced with manhandling this unit out of its hole and out the house? alternatives?
thanks!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 March 2011 - 04:35 PM
. . . looks like mine was made before roller assemblies became standard.
. . . faced with manhandling this unit out of its hole and out the house?
. . . alternatives?
1) serial number ? . . looks like prior to serial number M830453
2) why ?
3) fix it ?
#3 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 01 March 2011 - 04:46 PM
yup, prior to them doing rollers. this is the unit i have thrown different parts at for 3.5 years now. compressor is out and not being in my scope of repair skills the cost to have it repaired wasnt justifiable, so i have sourced a newer 632 which will be here tomorrow. i am giving this one away free and it is being picked up this evening.
i still have that 500 series manual you sent me a couple years ago, has come in real handy from time to time, cant thank you enough. hope i wont be neeing a 600 series repair manual any time soon. :)
#4 RegUS_PatOff
  • 33,588 posts
Posted 01 March 2011 - 05:11 PM
SubZero has a 12yr warranty on Sealed System parts
#5 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 02 March 2011 - 05:02 PM
could i go ahead and get a link to the 600 series tech manual? i'm going to need it to figure out how to hook up the water line for my ice maker. thanks! :beer:
#6 RegUS_PatOff
  • 33,588 posts
Posted 02 March 2011 - 05:05 PM
for the 600s, there's several manuals, depnding on model and serial number
#7 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 02 March 2011 - 05:07 PM
gotcha, its a 632 and i will have the serial number shortly, this one is still wrapped up on the pallet it just arrived on.
#8 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 02 March 2011 - 06:28 PM
serial number: P1904514
#9 RegUS_PatOff
  • 33,588 posts
Posted 02 March 2011 - 07:12 PM
600-1 Prior to Serial #1810000
600 Addendum For units starting with serial #1810000 > link PM'd
600-2 Built-In Approximate Starting Serial #2127000
600-3 Built-In Starting Serial #2600000
#10 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 02 March 2011 - 07:25 PM
awesome, thanks so much!
#11 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 02 March 2011 - 10:03 PM
plastic water line going from the solenoid to the ice maker was punctured along the way to me (maybe by me). can it be repaired rather than replaced?
#12 Tuco
Tuco
    Sōhei
  • Chief Appliantologist
  • 243 posts
  • Flavorite Brew:Tap Water
Posted 02 March 2011 - 11:16 PM
Should be replaced.
You might be able to cut the line at the punture and install a compression fitting.
Edited by Tuco, 02 March 2011 - 11:19 PM.
#13 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 02 March 2011 - 11:27 PM
Should be replaced.
thats certainly what i am hoping, will give that a shot, thanks
#14 kdog
    RoughShod
  • 7,465 posts
Posted 03 March 2011 - 12:59 AM
Pick your Poison:
http://www.repaircli...-Coupler/963908
http://www.repaircli...Coupler/1266836
http://www.repaircli...Coupler/1259380
http://www.repaircli...-Coupler/826505
http://www.repaircli.../4373559/584249
#15 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 03 March 2011 - 08:08 AM
thanks kdog. the one i get is dependent on the size line i have?
#16 jjbodean1970
jjbodean1970
    Ikkō-ikki
  • 49 posts
Posted 03 March 2011 - 10:39 AM
went to lowes, got the coupler i needed. snip, snip, push, push, done, no leak. for mine, it was 1/4" size, others, ymmv. thanks for all the feedback!
John Guest fittings
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 03 March 2011 - 02:40 PM
John who?
John Guest fittings are those magical fittings that connect plastic tubing in refrigerators and icemakers. The nice thing about them is they don't require any tools to make the connections; just push in/push out. To learn more about the in's and out's of John Guest fittings, see this post==>...
Read Full Entry →
