Frigidaire FEE368CCSD Range display blanks out
8 replies to this topic
#1 chipw
chipw
  • 4 posts
  • Flavorite Brew:lahtneppur dark
Posted 01 March 2011 - 09:43 PM
This started about 2 weeks ago that when the oven is turned on the Electronic Oven Controler goes blank that show the oven functions. The oven does not heat up in any mode. I can redo the inputs several times with the same results. Has the EOC failed or do i need to look at other parts of the unit?
  • 24,333 posts
Posted 02 March 2011 - 09:39 AM
More than likely. But need a valid model number to know for sure.
#3 RegUS_PatOff
  • 30,273 posts
Posted 02 March 2011 - 12:54 PM
FEE368CCSD
Posted Image My eyesight isn't as good as it once was (see RegUS_PatOff )
but from here it looks like that model number may be
FEF368CCSD
not much info on that c.1995 model
Do the Top Burners work OK when the Oven Controller blanks out ?
#4 chipw
chipw
  • 4 posts
Posted 02 March 2011 - 10:19 PM
I am told the stove top works fine even thou the oven display goes blank. The clock stay on and the timer also works.
And you are correct, it is a FEF368CCSD
Thanks for the responses
#5 RegUS_PatOff
  • 30,273 posts
Posted 02 March 2011 - 11:06 PM
then just the "Temperature Display" goes blank ?
#6 chipw
chipw
  • 4 posts
Posted 02 March 2011 - 11:10 PM
Sorry for the confusion.. The whole dispaly goes blank.. then about 10 sec later it comes back up. time is correct.. timer does count down. The display goes blank with in milli seconds of putting the oven in use...
#7 RegUS_PatOff
  • 30,273 posts
Posted 02 March 2011 - 11:13 PM
so... when you try to use the Oven, the Display goes blank, but then comes back ON.
and keeps repeating ON/OFF ?
and all during this time, the Oven doesn't heat but the Top Burners still work OK ?
#8 chipw
chipw
  • 4 posts
Posted 03 March 2011 - 01:04 AM
As long as u engage the oven it goes blank and comes back in about 10 sec.. u can repeat as often as you like in this mode. and yes.. all the top burner work good and correctly....
#9 RegUS_PatOff
  • 30,273 posts
Posted 03 March 2011 - 05:12 AM
maybe post a YouTube video ?
sounds like it would be a bad Controller
http://www.repaircli...?R=154&N=495738
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 03 March 2011 - 09:08 AM
A grasshopper posts:
Quote
Source:...
Read Full Entry →
