Kenmore washer 79640272 reset?
#1
Posted 02 March 2011 - 06:20 PM
#2
Posted 02 March 2011 - 07:32 PM
1) Add one bath towel to the tub/close door (this will mimic an unbalanced load).
2) Press: Power Button ("on")
3) Press: Spin Speed Button to *High*
4) Press: Start Button
5) Place one finger at each of the front leveling legs & wait until the Tub begins to accelerate to higher RPM spin.
If the left or right leveling leg begins to move or hop up/down---use the *LG wrench* to adjust the "leg" until it
stops (unsually 1/4 to 1/2 a turn).
On LG washers (and equivalent Kenmore models) with the "True Balance" feature---it is normal to observe the following:
1) 0 rpm to 400 rpm: Slight/low grade wobble of the washer as the tub begins to spin with *wet* laundry.
2) 400 rpm & above: Near perfect spin cycle. Very little or no Shakes/Vibration/Rattle etc for the duration of
the spin cycle.
3) As the spin cycle ends----the tub begins to slow down. 800rpm/700rpm/600rpm etc.
4) When the tub slows to 400rpm and comes to a dead stop---a slight wobble/vibration occurs (briefly).
All of the above is *normal*.
True Balance differs from older LG washers in that---on the older models---the ENTIRE spin cycle is an uncontrollable vibration/rattle/shaking/coiled-spring noise event. Start-to-finish.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3
Posted 02 March 2011 - 07:45 PM
Use the *correct* type & amount of detergent:
"HE" (High Efficiency) or Low Suds detergent *must* be used.
Three concentrations are sold--but the dosage instructions by the Soap & Detergent industry are *greedily* excessive.
Use the following dosage:
HE : (2) Tablespoon Per Wash Load
HE 3X: (1) Teaspoon
Prevents/Reduces:
1) Musty Odor
2) "LE" Error/Interrupted cycle
3) L-O-N-G Cycle Run Times (longer than time displayed)
4) Slower Spin Spin (wet laundry at end of cycle)
5) Small/Intermittent Water Leaks from Behind the Washer at the AIR VENT.
6) Poor Wash Results (especially whites)
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#4
Posted 02 March 2011 - 10:23 PM
If the washer is on a WOOD floor
the spin cycle.
The washer is on a concreat slab and does not lift.
As the washer goes from 500 or so RPM up to max speed the vibration is the worst and the door will rattle. If you push on the door you can make most of the noise go away. The service tech also seen this.
Do you know how to reset the controls or could have the spin speed been changed?
#5
Posted 02 March 2011 - 10:49 PM
If the washer *body* is shaking/vibrating---not normal. Especially on concrete flooring.
<<<If you push on the door you can make most of the noise go away.>>>
If this is the ONLY source of the offending "noise"---then this is resolved by adding shims to the DOOR LATCH/LOCK ASSY. The shims "move" the Latch Assy inward---resulting in a tighter door fit when closed.
<<<Do you know how to reset the controls or could have the spin speed been changed?>>>
The MAIN BOARD (or spin speed) is not "Field Serviceable".
Some LG built models **do** have capability for programming changes (or revised software profile) but ONLY via cellphone/wireless from LG. Normally--this is NOT required except when a problem has been identified that needs a software update. Very,very rare.
Spin Speeds can be set by the user on the Control Panel.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#6
Posted 02 March 2011 - 11:08 PM
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
Handling imbalance problems in LG - Kenmore front load washers
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 03 March 2011 - 08:56 AMIf the washer is on a WOOD floor---try:
5) Place...
Read Full Entry →
