Maytage Neptune Washer MAH3000AWW overflow
1 reply to this topic
#1 Novice360
Novice360
  • 1 posts
Posted 05 March 2011 - 12:06 PM
The water doesn't stop and overflows and then seeps through the bottom of the door. I've checked the control board on top...and it looks like the q6 and r11 is not burnt but a couple of tracks are burnt in the surrounding areas towards the first big plug in. When I unplug the washer, the water turns off. What do you guys think is wrong? Your help is appreciated.
    Shōgun
  • Master Samurai Tech
  • 30,396 posts
Posted 05 March 2011 - 01:43 PM
Try the Basic Motor Function Test described on this page==> http://fixitnow.com/...eptune-washers/
