GE Profile Arctica Door Water Dispenser Won't Turn Off
13 replies to this topic
#1 jdabkowski
jdabkowski
  • 9 posts
  • Flavorite Brew:Ninkasi IPA
Posted 05 March 2011 - 09:29 PM
I have a GE Profile Arctica, Model No. PSC23SGMD BS that when after filling a glass of water from the dispenser on the door, the dispenser keeps outputting water for 3-4 seconds then stops. Is the part that controls that function in the door or behind the refrigerator?
  • 24,349 posts
Posted 05 March 2011 - 10:21 PM
Have you changed the filter recently?
#3 jdabkowski
jdabkowski
  • 9 posts
Posted 05 March 2011 - 10:55 PM
Today. Along with the filter bracket and tubing that extends down the back of the refrigerator to a switch assembly (which I'm looking for a name for...).
#4 kdog
    RoughShod
  • 7,428 posts
Posted 05 March 2011 - 11:05 PM
Does it come out with full force ,as when you depress the switch or lever; Or - is it more like a "dribble" ?
#5 jdabkowski
jdabkowski
  • 9 posts
Posted 05 March 2011 - 11:11 PM
It comes out full force when I depress the lever, then continues at full force for 3-4 seconds after I let go of the lever.
Where can I find a parts diagram for this model?
  • 24,349 posts
Posted 05 March 2011 - 11:24 PM
Was it doing the run-on problem before you replaced the filter?
#7 kdog
    RoughShod
  • 7,428 posts
Posted 05 March 2011 - 11:39 PM
For manuals and lots of other goodies, become an Apprentice==> http://appliantology.org/apprentice/
#8 jdabkowski
jdabkowski
  • 9 posts
Posted 06 March 2011 - 12:04 AM
Yes, it was doing it sometimes and sometimes not before I changed the filter. Now it appears to be consistently doing it.
  • 24,349 posts
Posted 06 March 2011 - 05:59 AM
Probably got air in the water line. Try running a bunch of water thru the dispenser, several minutes worth.
#10 DurhamAppliance
    Sho' Nuff Chozin
  • 1,750 posts
Posted 06 March 2011 - 09:10 AM
If water purging does not work, look to the spring mechanism connected to the water dispenser button. When you press the button it engages a microswitch that energizes the water valve. Upon release, the microswitch disengages valve. Sometimes button can get gunky or the microswitch becomes lethargic. If all of this fails, then you may be in the market for a new water valve. I doubt it is the latter since the leaking stops after a short period. However, you want to keep an eye on this. A water valve can lose resistance and even without the dispenser button being depressed,....well let's just say your fridge will look like it is relieving itself all over your expensive wooden floors. Sort of like me last night after "several" brews (sans expensive floors) in celebration of Carolina's victory over Duke. Go Heels!
Edited by DurhamAppliance, 06 March 2011 - 10:34 AM.
#11 jdabkowski
jdabkowski
  • 9 posts
Posted 06 March 2011 - 02:27 PM
I certainly support your enthusiasm of ANYONE beating Duke! How do I get access to the spring to clean it? I'll try pumping a bunch of water through it too first. Thanks (and go UCONN!)
#12 Samurai Appliance Repair Man
  • 24,349 posts
Posted 06 March 2011 - 04:06 PM
... the microswitch disengages valve. Sometimes button can get gunky or the microswitch becomes lethargic.
Egzellent pernt on the microswitch, Durham-- I had forgotten about that little trick. :thumbsup:
#13 jdabkowski
jdabkowski
  • 9 posts
Posted 06 March 2011 - 04:46 PM
I pumped a bunch of water through it, but it didn't get any better. How do I get at that button/spring?
#14 DurhamAppliance
    Sho' Nuff Chozin
  • 1,750 posts
Posted 06 March 2011 - 05:31 PM
I have had to purge several gallons to stop a leak. With regards to accessing dispenser check out http://appliantology..._1#entry187378. Better yet, become an apprentice, save $$ and get a service manual
