LG WM2101 washer bleach dispenser not completely flushing
5 replies to this topic
#1 robinasu
robinasu
  • 14 posts
Posted 08 March 2011 - 02:58 PM
Hi, I just bought a LG WM2101 and the bleach tray doesn't flush completely, which is surprising. I have watched the operation of the machine and it seems the bleach portion of the tray is only filled once, which starts the siphon action to drain the tray. There is a decent amount of bleach/water mix left in the tray and I'm concerned colored clothes will be affected on the next load. Is this a common?
I can confirm I have, what I believe, is good water pressure. Water does indeed fill the tray and I do not fill the bleach tray above the max line. I would be surprised if there is an obstruction since there are water strainers on the water inlets. I'm surprised the machine doesn't fill the tray twice just to be sure.
Thanks, Rob
#2 john63
john63
    Dean of LG Appliantology
  • 2,218 posts
Posted 08 March 2011 - 10:18 PM
<<<I just bought a LG WM2101 and the bleach tray doesn't flush completely>>>
A commonly asked question.
In nearly all cases---the BLEACH did in fact---dispense into the tub at the appropriate time during the cycle.
In nearly all front loading washers with a *drawer* type dispenser assembly---a small amount of water remains in the dispenser compartments (Prewash/Main Wash/Bleach Liquid/Fab Softener).
To verify that the bleach dispenser is indeed functioning correctly...
After a cycle ends---open the drawer and "dip" your finger into the bleach dispenser.
Smell the liquid--if a *heavy* bleach odor is present then the dispenser failed to function.
If the smell has a *faint* bleach odor---normal.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 robinasu
robinasu
  • 14 posts
Posted 08 March 2011 - 10:50 PM
I see what you mean. The remainder is a mix of bleach and water. I am very surprised LG did not just fill the tray a second time about 10 seconds later. Doesn't seem right. I don't want to bleach my clothes, not even a little.
#4 john63
john63
  • 2,218 posts
Posted 08 March 2011 - 11:11 PM
<<<The remainder is a mix of bleach and water.>>>
A *trace* amount(residual). Certainly not enough to stain dark clothing.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#5 robinasu
robinasu
  • 14 posts
Posted 08 March 2011 - 11:21 PM
Hmm fair enough. The German in me would have filled the tray twice. : ) Thanks for your input, John.
#6 john63
john63
  • 2,218 posts
Posted 08 March 2011 - 11:28 PM
Your welcome, Rob.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
Bleach dispenser in a new LG washer is not flushing completely
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 08 March 2011 - 10:22 PM
Let Sublime Master john63 put your mind at ease...
In nearly all cases---the BLEACH did in...
Read Full Entry →
