Hotpoint refrigerator with abundance of annoying issues
5 replies to this topic
#1 Lego7191
Lego7191
  • 4 posts
Posted 25 April 2005 - 01:29 PM
Several problems with this Hotpoint fridge.  I could get the model number if necessary, but I will start with the problems.
1 - Fridge freezes everything SOLID.  Not a little frosty or icy, but completely SOLID blocks of ice....even when thermostat is turned to the lowest setting, 1 or OFF, it still freezes all contents solid....which brings us to problem number 2
2 - The temperature control knob seems to do NOTHING.  I can turn it to OFF, I can turn it to 9 (coldest setting), or somewhere in between...it never shuts off and it never thaws the contents out.
3 - towards the back of the fridge, on the top (which would be the freezer floor if htat helps indicate the location I am trying to describe), it LEAKS.  Water just drips from that area of the fridge (actually in the fridge, it is not coming from the freezer) and I have to have a jug there to catch the water.  Otherwise, it drips all over whatever is in its path and then I have a sheet of ice on top of whatever it happens to land on.
HELP PLEASE.
#2 Lego7191
Lego7191
  • 4 posts
Posted 25 April 2005 - 01:32 PM
Okay, I got off my keister and got the model no.  CTX18LYYBRWH
thanks in advance for any and all help to solve these annoying issues.
  • 24,243 posts
Posted 25 April 2005 - 01:55 PM
Ah, Grasshoppah, look beyond to where the many become one and you will see that all these seemingly unrelated problems stem from the same root cause:  a bad cold control.  Come git you one
