GE washer- motor doesn't run during agitate
3 replies to this topic
#1 tilemantas
tilemantas
  • 2 posts
Posted 10 March 2011 - 08:18 PM
I have a ge washer.
It fills,wont agitate to wash,drains and spins.
Makes no noise or sound during wash cycle does nothing during wash cycle but works fine on all other cycles.
Replaced the timer with a brand new timer
.Checked belt_tight and shows no wear at all still looks new.
Any help would be greatly appriciated.
Thank you
    Shōgun
  • Master Samurai Tech
  • 30,956 posts
Posted 10 March 2011 - 08:49 PM
Are you positive it spins? Did you open the lid and see the basket coming to a stop? If so, then the next stop would be the pressure switch, probably a burned out contact at the violet wire so the pressure switch cuts off the water inlet valves properly but can't make the connection to complete the motor circuit.
Pressure switch part link==> http://www.repaircli...er=WDSR2080D5WW
#3 tilemantas
tilemantas
  • 2 posts
Posted 11 March 2011 - 03:41 PM
You definatly know your washers.
The violet wire was the issue.
Wish I had of asked you, before I bought the timer switch!!!
Thank so much and will tell all my friends.
    Shōgun
  • 30,956 posts
Posted 11 March 2011 - 03:45 PM
On the other hand, you're still ahead of the game fixing it yourself! Posted Image
