Kenmore gas range oven & broiler won't Ignite
6 replies to this topic
#1 addnup
addnup
  • 3 posts
Posted 13 March 2011 - 02:00 PM
I have a Kenmore Gas Range, Model 362.7585590 and the other day while I was baking dinner, it just stopped heating. Now I have nothing. Two years ago, I replaced the ignitor and I'm thinking it is the same issue. The coil looks broken on the oven ignitor and I can replace that again. But the broiler will not light either. Can the problem be more than the ignitor? The burners on the range still light. Thanks....
  • 24,709 posts
Posted 13 March 2011 - 02:18 PM
It's possible the bimetal in the gas valve is open. Only way to really know what's going on is to see if you're getting 120vac at the ignitor leads.
#3 RegUS_PatOff
  • 30,698 posts
Posted 13 March 2011 - 02:28 PM
Kenmore 362.7585590 made by GE
I don't think there's anything in common with Bake & Broil on that model
Check voltages at the Ignitors,
OR test for about 3v AC across the Bake Terminals and across the Broil Terminals of the Gas Safety Valve.
May also be a bad Controller
Edited by RegUS_PatOff, 13 March 2011 - 02:42 PM.
#4 addnup
addnup
  • 3 posts
Posted 13 March 2011 - 02:29 PM
How do I check that?
  • 24,709 posts
Posted 13 March 2011 - 03:23 PM
Some of the photos in this post show you where the ignitor wiring is.
Do you have a multimeter?
#6 addnup
addnup
  • 3 posts
Posted 13 March 2011 - 03:30 PM
yes but its been a long time since it has seen daylight....
  • 24,709 posts
Posted 13 March 2011 - 03:32 PM
Basic primer on making simple electrical measurements here.
