Sign in to follow this
Followers 0
94MKIV
Samsung WF448AAP Error Message
6 posts in this topic
I did a search but could not find an answer. This washer is 2 months old and has not been used more than 15 times. Was doing some laundry today and a few minutes into the cycle, I got an screen message stating Error: Water Leakage Problem and says to call a service tech. Inspection of the machine shows no visible water anywhere under or behind the unit. Turned the unit back on and simply ran the Rinse & Spin setting to finish the load. I then started another load and basically got the same results with the error code coming up again.
Anything I can do try and correct this problem before going through the nightmare of having Samsung come out and service the unit? Pretty ridiculous that the unit is a few months old and already down with a problem.
When the error occurred---was the STEAM option selected/used?
If yes---Samsung has published a bulletin relating to a *leak* at the check valve on the STEAM GENERATOR.
This calls for a STEAM KIT ASSY p/n: DC97-09101J
Edited by john63
Could be a leak, a faulty sensor or board. Because of how new the machine is, I think it would be best to call in the Samsung Tech. You need to go ahead and get the problem on record.
Also, make sure that drain hose hasn't been stuffed too far into standpipe - if the hose is submerged in the water in the drain trap it can syphon out
Great tip! Useful for all washers. We hate getting paid just for retracting a drain hose. :)
Thanks for the great info. The wife ran another load today and it had no problem. I'll check the drain house and if the I get the error again, I'll give Samsung a call since it is still under warranty.
Followers 0
