GE washer
12 replies to this topic
#1 Guest_jager_*
Guest_jager_*
  • Lurking at the Threshold
Posted 01 April 2005 - 01:43 PM
Washer not running and nothing in it, It fills itself up with water and over flows. What's up with that.  We need to turn the water off every time we finish doing a laundry.
Yikes :shock:  drowned my camping gear.
#2 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 01 April 2005 - 01:45 PM
WH13X86 fill valve if it's a new style.
Generic CW151 fill valve  if it's old style.
  • 24,218 posts
Posted 01 April 2005 - 03:48 PM
New style valve:
To buy the part, CLICK HERE.
#4 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • PipPipPipPip
  • 691 posts
Posted 01 April 2005 - 04:39 PM
The old Style valve
To buy this part CLICK HERE
#5 Guest_jager_*
Guest_jager_*
Posted 01 April 2005 - 05:48 PM
My life is saved, thank you. I will camp this year after all.
Jager:D
  • 24,218 posts
Posted 01 April 2005 - 05:55 PM
Which one was it?
#7 Hank
Hank
  • 3 posts
Posted 05 April 2005 - 06:36 PM
I may have the fill valve you need. It is used. It came off the 1998 washer in question. Let me know.
#8 Guest_jager_*
Guest_jager_*
Posted 05 April 2005 - 06:40 PM
I took it apart and cleane it. we have a ton of iron in our water and it caked on the seals.
I'll let you know if it dies and I need the one you have.
 thanks,          Harley
#9 XNSXMANNY
XNSXMANNY
    Ikkō-ikki
  • Master Appliantologist
  • 42 posts
Posted 05 April 2005 - 08:58 PM
why do people test fate. if its broke replace it, you may get away with cleaning it for a short period of time or you just may in a day or two when you least expect it flood your house. for the price of the valve i'de rather be certain that its not gonna fail. but thats just me i guess
  • 24,218 posts
Posted 06 April 2005 - 02:30 AM
I've been to houses that have had $20,000 worth of flood damage for that very reason.  Once you remove the protective inlet screen, you distort it so it no longer seals the water inlet correctly and the valve is vulnerable to sediment damage, such as getting stuck in the open position.  They realized after the fact how silly it was to save $20 by not replacing the valve only to incurr $20,000 worth of water damage to their house.  Some lessons in life are expensive. :dude:
#11 Guest_jager_*
Guest_jager_*
Posted 06 April 2005 - 04:11 AM
Threat of divistation and scare tactics, come on now guys.:( I am a certified jet mechanic and ASE auto cert.  I back flushed the screen, it's fine. Te plastic was not damaged, I used CLR to desolve the built up rust and it works great, thanks for your concern.
 From now on please no more cying wolf, just the facts.;)
#12 Samurai Appliance Repair Man
  • 24,218 posts
Posted 06 April 2005 - 04:37 AM
No one was threatening anything.  I was merely relating a real-life service call story for the benefit of others reading this.  If you took it as a scare tactic, perhaps that's your own insecurities coming out.  Good luck with that "repair."
P.S.  I worked as an avionics technician at Delta Airlines when I first got out of the Navy.  What a bunch of jack-leg hacks!  Present company exempted, of course.  ;)
  • 24,218 posts
Posted 06 April 2005 - 06:51 AM
For anyone interested in learning more about water inlet valves and the problems that improper maintenance on them can cause, come read this page.
