Maytag Washer model MAH3000AWW
5 replies to this topic
#1 pjjp21
pjjp21
  • 13 posts
Posted 25 April 2005 - 01:54 PM
hi
my maytag will not spin.  everything else seems ok but when it gets to the spin cycle it just sit there...i checked the circuit board  r11, r43 and i belive Q6, all appear fine, nothing fried.....
  • 24,199 posts
Posted 25 April 2005 - 02:07 PM
Does the door lock light come on?  If so, then we need to check the voltage and continuity in the unbalance circuity.  Also wanna check the integrity of the connections on the machine control board.
If we need to get into the unbalance circuit, I'll need to see your tech sheet/wiring diagram.  Open the control panel and you'll find it inside.  Post it here or fax it to me at 775-416-4449.
#3 pjjp21
pjjp21
  • 13 posts
Posted 25 April 2005 - 02:24 PM
i be lieve i found the problem, it was the door lock spin enable switch, i am going to replace that, should i also replace door wax motor?
  • 24,199 posts
Posted 25 April 2005 - 02:50 PM
If it's the original wax motor, it'd be a good idea to go ahead and replace it-- the wax motor was the culprit behind all the machine control board burnouts.
#5 pjjp21
pjjp21
  • 13 posts
Posted 25 April 2005 - 02:52 PM
i thank you for all your help, i will be adding to the beer fund!!!
  • 24,199 posts
Posted 25 April 2005 - 02:54 PM
Mucho domos!  I appreciate your support!  :D
