MDE5500 AYW serial #10 Blower Fan Removal
2 replies to this topic
#1 Fog
Fog
  • 2 posts
  • Flavorite Brew:Fat Tire
Posted 16 March 2011 - 11:15 AM
I have removed the clamp from the fan collar and split-ring retainer from the motor shaft. Fan still will not budge. Looks like it might take a special tool. Any Ideas on how to finish removing it?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 16 March 2011 - 02:01 PM
Blower Wheel
The blower wheel is attached directly to the motor shaft behind the blower cover.
Whenever replacing a blower wheel, always replace the clamp.
Removal
1. Disconnect power to the machine.
2. Remove front panel and close door.
3. Remove shroud/tumbler front assembly.
4. Remove blower cover.
5. Remove clip retaining ring.
6. Compress and remove clamp around hub of impeller.
7. Work blower wheel back and forth while pulling off shaft. It may require considerable effort to remove the blower wheel.
For manuals and lots of other goodies,
become an Apprentice==> http://appliantology.org/apprentice/
#3 Fog
Fog
  • 2 posts
Posted 16 March 2011 - 04:34 PM
That did it. Thanks. It was a struggle but it finally came free.
And of course the motor is not making noise anymore - replacing it anyway :-(
