rknoble
Whirlpool Calypso starts,stops,starts,stops....
10 posts in this topic
Whirlpool Calypso (mod GVW9959KQ2) cycles on and off in intermittent bursts starting in the rinse cycle and through the spin cycle. Water enters and drains, but the machine wont continue to run. There is no error code and the tub doesn't spin. Seems like the brake is on. A "professional" repairman on another board was posed with the same problem and said it was the motor control board. I spent the $200 for that baby, popped it in and...no change. Another guy said he had the same problem and it turned out to be the bearing in the inner wash plate. I took this machine apart and found that that bearing was toast, so I rebuilt the top end from the u-joint up. Another $200 not including the assembly fluid (Stone IPA). Problem still exists. So I'm into this thing now for half the cost of a new machine and don't want to kick it to the curb. I fix everything around the house and that is expected of me from my family now. Any suggestions so I can maintain my hero status?
Additional information: The cycle tests outlined in the repair manual run normally. When the machine begins its trouble during a normal wash, I've found that opening the lid for a few minutes, then restarting, it will function normally for a few minutes. I'm thinking that something is overheating.
Bummer, deeuude. Can you return the board? Fun fact to know and tell: If you buy parts through this site, you can return them for exchange or refund for a a full year; no harm in buying and trying.
...that bearing was toast, so I rebuilt the top end from the u-joint up. Another $200 not including the assembly fluid (Stone IPA). Problem still exists
What are the part numbers of the parts you installed here?
What happens to the display when it quits, starts flashing ? - goes blank ?
could be a short in the lower wire harness ohm it out and check common with this machine
Thanks for your replies guys, I'm about out of ideas here and I appreciate your input..
The part number replaced: 285927 u-joint kit.
The bearing is in the top of the brown dome. While there wasn't any water in there when I disassembled it, there was corrosion on the metal parts. The aluminum was crusty and the bearing had rust on/in it. I never saw water under the machine and see no evidence under the outer tub.
When the machine "stalls", the panel reads normally. The display shows the remaining time. No flashing.
I'll try that harness test right after I finish this beer so I'll be in a better "place" when the dog sticks her nose in my ear.
is the Motor hot at that time ?
The motor is not hot. Wash cycles run normally, it's in the rinse cycle that it acts like the power shuts down to both motors.
Another odd thing, it always starts the condition at the same countdown time (23 minutes in normal wash), when it happens. Sometimes it doesn't, but that is rare.
Well guys, seems it was the water pump (there is a separate two piece pump on this model). The wheel was binding in the pump box and must have been overloading the motor and shutting down the whole drive system. Thanks again for your input. Now on to the next repair...
