GE Dishwasher gsd5211pww
4 replies to this topic
#1 Sonic
Sonic
    Sōhei
  • Chief Appliantologist
  • 130 posts
  • Flavorite Brew:Alexander Kieths
Posted 17 March 2011 - 12:36 PM
Is the fill on this dishwasher timed or is it controlled by the float? And would it over fill if not leveled properly?
    Shōgun
  • Master Samurai Tech
  • 29,061 posts
Posted 17 March 2011 - 05:31 PM
It's timed. The float is just there as a backup safety device in case the valve gets mechanically stuck open.
#3 Sonic
Sonic
    Sōhei
  • 130 posts
Posted 17 March 2011 - 06:31 PM
Ok thanks, I thought so but i didn't hurt to ask.
#4 Budget Appliance Repair
  • 4,722 posts
Posted 18 March 2011 - 05:22 AM
Come on Samurai, you know better then that!!!!!
If the valve gets machanically stuck open lifting the float or unplugging the machine isn't going to stop the flood!!!!
Now if the timer gets stuck in the fill position or the timer fill contact points weld together or the flow washer in valve is to big, (someone puts wrong valve in), that's basically what the float switch takes care of, would have to be something sending power to the fill valve for too long for the float switch to come into the picture and save from a flood.
William Burk (Willie)
Eureka, CA 95501
    Shōgun
  • 29,061 posts
Posted 18 March 2011 - 07:57 AM
Of course I knew that! I just said it that way cuz I haven't seen you on in the past couple days and I knew it was a sure way to get you to post! ;)
